Exporting Text to excel
Hi All,
I have a little problem with modifying some code I found on Lee Mac's website.  I hope someone on here well versed on autocad programming can help me out.  Are there any ways to modify the code so that it lists the texts/mtxt/attr in an order from left to right as it appears in the drawing (also adding an x,y coordinate next to each text)? Also, are there ways to add a condition to only list texts/mtxt/attr that has 3 decimal places?
;; Text 2 CSV  -  Lee Mac
;; Writes all Text, MText & Attribute content from all layouts and within
;; all blocks and nested blocks to a selected CSV file.
(defun c:txt2csv ( / data file )
    (cond
        (   (not
                (progn
                    (vlax-for block (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
                        (if (eq :vlax-false (vla-get-isxref block))
                            (vlax-for obj block
                                (cond
                                    (   (wcmatch (vla-get-objectname obj) "AcDb*Text")
                                        (setq data (cons (vla-get-textstring obj) data))
                                    (   (and
                                            (eq "AcDbBlockReference" (vla-get-objectname obj))
                                            (eq :vlax-true (vla-get-hasattributes obj))
                                        (foreach att (vlax-invoke obj 'getattributes)
                                            (setq data (cons (vla-get-textstring att) data))
                    data
            (princ "\nNo Text, MText or Attributes found.")
        (   (not (setq file (getfiled "Create CSV file" "" "csv" 1)))
            (princ "\n*Cancel*")
        (   (setq file (open file "w"))
            (foreach x data (write-line x file))
            (setq file (close file))
            (princ (strcat "\n" (itoa (length data)) " strings written to file."))
        (   (princ "\nUnable to open CSV file for writing."))
    (princ)
(vl-load-com) (princ)
Thanks you for reading!
TheCADnoob
your question may be better fielded in the section which commonly deals with lisps here : http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Im not sure listing the elements in the order as they are seen in the drawing is going to be that simple, but as i wount be able to get what you need ill let those who are in the know make that determination.
Also have you tried using DATAEXTRACTION
CADnoob
3wood
To convert texts into an Excel file, you can try TEXT2CSV.
sameerulcdc
Hi
can this lsp modify to user selection option particular area
Thank you
ec-cad
Very 'old' thread here, but attached Lisp will extract Attributes, Mtext & Text to a .csv file called
Text_to_csv.csv in the current folder. It (doesn't Unformat the Mtext), you can find that Lisp here.
Will allow Window / Crossing pick of what you want to export.
ECCAD
Sea-Haven
One of the requests was do a sort on the objects so they are bottom left sorted. With X & Y. You can do a sort on X & Y. So would make a list then sort it, then say write the csv, so would have 3 lists Atts, Mtext & Text.
; sorts on 1st two items
(vl-sort lst
	 '(lambda (a b)
	    (cond
	      ((< (car a) (car b)))
	      ((= (car a) (car b)) (< (cadr a) (cadr b)))
An example but depends on how you make the list, expects X & Y as items 1 and 2.
For me I would write direct to Excel and remove need for a csv step. Your welcome to use "Alan excel library.lsp", if a table is wanted also can either make a table then use a lisp I have, Export table to excel, or do both in one code set.
You are right about remove Mtext formatting also. Multi line required single cell in Excel ?
Really need a sample dwg from Anonymous with a required resulting Excel, before doing any code.
Sea-Haven
"Add an option to restrict to 3 decimal places."
Are you talking about the X & Y values of the text then just use (rtos x 2 3) (rtos Y 2 3) I won't go into padding for moment.
