Angle Mismatch Dynamic block
jaimuthu
jaimuthu
(defun c:SB(/ o pt va di ang params paramName)
  (setq
    pt    (getpoint "\nPick a first point:")
    va    (getpoint pt "\nPick a second point:")
    di    (distance pt va)
    ang   (angle pt va)
  (command "ZOOM" "S" pt va)
  (command "_.Insert" "D:/kk/OTHERS/1.DWG" pt "" "" "")
  (setq o (vlax-ename->vla-object (entlast)))
  (vla-rotate o (vlax-3d-point pt) ang)
  (setq params (vlax-safearray->list (vlax-variant-value (vla-GetDynamicBlockProperties o))))
  (foreach a params
    (setq paramName (vla-get-PropertyName a))
    (if (wcmatch paramName "*X*")
      (vla-put-value a (vlax-make-variant di 5))
  (command "ZOOM" "P")
  (princ)
i pick two points distance is ok but angle is mismatch that is i pick first point second point i pick 0 angle side but its come angle is 45
paullimapa
try these modifications:
(defun c:SB(/ o pt va di dx dy ang params paramName)
  (setq
    di    (distance pt va)
    ang   (angle pt va)
    dx    (- (car va) (car pt)) ; deltax
    dy    (- (cadr va) (cadr pt)) ; deltay
;  (vla-rotate o (vlax-3d-point pt) ang)
  (foreach a params
;      (vla-put-value a (vlax-make-variant di 5))
      (vla-put-value a (vlax-make-variant dx 5)) ; deltax
    (if (wcmatch paramName "*Y*")
      (vla-put-value a (vlax-make-variant dy 5)) ; deltay
  (princ)
Paul Li
IT Specialist
@The Office
jaimuthu
its work fine Thanks
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
