Ramer–Douglas–Peucker algorithm Lisp Assistance
jdlevinson95
jdlevinson95
I am in the process of creating a lisp to help with decimating polylines with many points while minimizing the variation from the original polyline. I am using the Ramer–Douglas–Peucker algorithm. Reference can be found here. I think there is an issue with the recursion part and outputting the new polyline points. I would also appreciate any advice in cleaning up the code in general and simplifying it. Below is the code I have currently written as well as a version I have previously made to work in excel for reference.
;	# source: https://karthaus.nl/rdp/
;	function DouglasPeucker(PointList[], epsilon)
;		# Find the point with the maximum distance
;		dmax = 0
;		index = 0
;		end = length(PointList)
;		for i = 2 to (end - 1) {
;			d = ShortestDistance(PointList[i], Line(PointList[1], PointList[end]))
;			if (d > dmax) {
;				index = i
;				dmax = d
;		ResultList[] = empty
;		# If max distance is greater than epsilon, recursively simplify
;		if (dmax > epsilon) {
;			# Recursive call
;			recResults1[] = DouglasPeucker(PointList[1...index], epsilon)
;			recResults2[] = DouglasPeucker(PointList[index...end], epsilon)
;			# Build the result list
;			ResultList[] = {recResults1[1...length(recResults1) - 1], recResults2[1...length(recResults2)]}
;		} else {
;			ResultList[] = {PointList[1], PointList[end]}
;		# Return the result
;		return ResultList[]
(defun C:RDP_Decimate (/ ent PL0 PL RowLast epsilon output)
  (setq ent (entsel "\nPick POLYLINE to list vertices:"))
  (if
    (and ent
         (wcmatch (cdr (assoc 0 (entget (setq ent (car ent))))) "*POLYLINE") ;all types
    ) ;and
    (setq PL (PolyVert ent)) ;make list
  ;(setq PLz (mapcar 'caddr PL))
  ;(setq PL (mapcar 'reverse (mapcar 'cdr (mapcar 'reverse PL0)))) ;remove z coordinates
  (setq RowLast (- (length PL) 1) ;end = length(PointList) // subtracting 1 because indices start at 0 while length command starts at 1
        epsilon (getreal "\nEpsilon:") ;set value of epsilon
  (setq output (RDP PL epsilon RowLast)) ;save the result
  ;(princ output) ;print the result (this is an error checking step during development. Comment out at end)
  (PLDraw output) ;draw the result
(defun RDP (PLxyz eps end / PLx PLy dmax d index iter ArrRes1 ArrRes2 RecRes1 RecRes2
            Res
  (setq PLx   (mapcar 'car PLxyz)
        PLy   (mapcar 'cadr PLxyz)
        dmax  0.0
        index 0
        iter  1 ;this is assuming that the indices start at 0
  (while (<= iter (- end 1))  ;for i = 2 to (end - 1)
    (setq d (MinDist PLx PLy)) ;d = ShortestDistance(PointList[i], Line(PointList[1], PointList[end]))
    (if (> d dmax)  ;if (d > dmax) {
      (setq index iter ;index = i
            dmax  d ;dmax = d
    (setq iter (1+ iter))
  (if (> end index)  ;assuming indices start at 0
    (progn
      ;ResultList[] = empty
      (setq ArrRes1 (car (ArrCut PLxyz index)) ;ArrRes1=PLxys(1,...,index)
            ArrRes2 (cadr (ArrCut PLxyz index)) ;ArrRes2=PLxyz(index,...,end)
             ;ArrRes2 (member (nth index PLxyz) PLxyz) ;ArrRes2=PLxyz(index,...,end)
             ;ArrRes1 (reverse (member (car ArrRes2) (reverse PLxyz))) ;ArrRes1=PLxys(1,...,index)
      (if (> dmax eps)  ;if (dmax > epsilon) {
        ;# Recursive call
        (setq RecRes1 (RDP ArrRes1 eps (length ArrRes1)) ;recResults1[] = DouglasPeucker(PointList[1...index], epsilon)
              RecRes2 (RDP ArrRes2 eps (length ArrRes2)) ;recResults2[] = DouglasPeucker(PointList[index...end], epsilon)
               ;# Build the result list. Note that the last term of RecRes1 should be the same as the first term of RecRes2
              Res     (append RecRes1 (cdr RecRes2)) ;ResultList[] = {recResults1[1...length(recResults1) - 1], recResults2[1...length(recResults2)]}
        (setq Res (list (car PLxyz) (last PLxyz))) ;else {ResultList[] = {PointList[1], PointList[end]}
    (setq Res PLxyz)
  ;sort the result list from least to greatest x values
  ;(vl-sort Res
  ;         (function
  ;           (lambda (e1 e2)
  ;             (< (car e1) (car e2))
) ;return Res
; PolyVert
; returns vertices list for any type of polyline (in WCS coordinates)
; arg POLY: polyline to list (ename or vla-object)
(defun PolyVert (POLY / par pt1 lst)
  (vl-load-com)
  (setq par (if (vlax-curve-isClosed POLY)
              (vlax-curve-getEndParam POLY) ; else
              (1+ (vlax-curve-getEndParam POLY))
  (while (setq pt1 (vlax-curve-getPointAtParam POLY (setq par (- par 1))))
    (setq lst (cons pt1 lst))
) ;; return lst
;	If the line passes through two points P1=(x1,y1) and P2=(x2,y2) then the distance of (x0,y0) from the line is:
;	MinDist(P1,P2,(x0,y0))=Abs((y2-y1)*x0-(x2-x1)*y0+x2*y1-y2*x1)/sqrt((y2-y1)^2+(x2-x1)^2)
(defun MinDist (ArgX ArgY / y0 x0 y1 x1 y2 x2)
  (setq y0 (nth iter ArgY)
        x0 (nth iter ArgX)
        y1 (car ArgY)
        x1 (car ArgX)
        y2 (last ArgY)
        x2 (last ArgX)
  ;		Abs((y2-y1)*x0-(x2-x1)*y0+x2*y1-y2*x1)->(abs (+ (- (* (- y2 y1) x0) (* (- x2 x1) y0) (* y2 x1)) (* x2 y1)))
  ;		sqrt((y2-y1)^2+(x2-x1)^2)->	(+ (expt (- y2 y1) 2) (expt (- x2 x1) 2))
  (setq d (/
;draw the polyline
(defun PLDraw (listpts / x)
  (command "_pline") ;start pline command
  (while (= (getvar 'cmdactive) 1)  ;while a command is running loop (it is because we haven't entered any points)
    (repeat (setq x (length listpts))  ;repeat loop (sets x to length of your list) repeat x times
      (command (nth (setq x (- x 1)) listpts)) ;because this is still inside the pline command it evaluates the expression (nth item (x-1) of list listpts
    ) ;end repeat                              ;length gives you number of items in list but list is 0 based so first item is 0 and last is (x-1)
    (command "") ;end pline command with a return ("")
  ) ;end while
;Cuts an array at a specified index and returns a list of 2 arrays that start and end at the given index respectively
;Note that indices start at 0 when choosing the CutIndex
(defun ArrCut (Arr CutIndex / Arr1 Arr2 ArrList)
  (setq Arr2 (member (nth CutIndex Arr) Arr) ;Arr2=PLxyz(index,...,end)
        Arr1 (reverse (member (car Arr2) (reverse Arr))) ;ArrRes1=PLxys(1,...,index)
  (setq ArrList (list Arr1 Arr2))
Sub CallRamerDouglasPeucker()
Dim pointList As Variant
Dim rowCount As Integer
Dim result As Variant
Dim epsilon As Double
    Call ClearOutput
    pointList = Sheets("Full").Range("Full")
    rowCount = UBound(pointList)
    epsilon = Sheets("Full").Range("epsilon")
    result = RamerDouglasPeucker(pointList, epsilon, rowCount)
    WriteResult (result)
End Sub
Function RamerDouglasPeucker(pointList As Variant, epsilon As Double, rowCount As Integer) As Variant
    Dim dMax As Double
    Dim Index As Integer
    Dim d As Double
    Dim arrResults1 As Variant
    Dim arrResults2 As Variant
    Dim resultList As Variant
    Dim recResults1 As Variant
    Dim recResults2 As Variant
    ' Find the point with the maximum distance
    dMax = 0
    Index = 0
    For i = 2 To (rowCount - 1)
        d = Abs((pointList(rowCount, 1) - pointList(1, 1)) * (pointList(1, 2) - pointList(i, 2)) - (pointList(1, 1) - pointList(i, 1)) * (pointList(rowCount, 2) - pointList(1, 2))) / Sqr((pointList(rowCount, 1) - pointList(1, 1)) ^ 2 + (pointList(rowCount, 2) - pointList(1, 2)) ^ 2)
        If d > dMax Then
            Index = i
            dMax = d
    Next i
    'Testing if can stop cut going to index 0
    If Index > 1 Then
        arrResults1 = Cut_Array(pointList, 1, Index)
        arrResults2 = Cut_Array(pointList, Index, rowCount)
        ' If max distance is greater than epsilon, recursively simplify
        If (dMax > epsilon) Then
            ' Recursive call
            recResults1 = RamerDouglasPeucker(arrResults1, epsilon, UBound(arrResults1))
            recResults2 = RamerDouglasPeucker(arrResults2, epsilon, UBound(arrResults2))
            ' Build the result list
            resultList = Join_Array(recResults1, recResults2)
        Else
            ReDim resultList(1 To 2, 1 To 2)
            resultList(1, 1) = pointList(1, 1)
            resultList(1, 2) = pointList(1, 2)
            resultList(2, 1) = pointList(rowCount, 1)
            resultList(2, 2) = pointList(rowCount, 2)
    Else
        resultList = pointList
    ' Return the result
    RamerDouglasPeucker = resultList
End Function
Function Cut_Array(arr As Variant, arrStart As Integer, arrEnd As Integer) As Variant
    ReDim resultList(1 To (arrEnd - arrStart) + 1, 1 To 2)
    For i = arrStart To arrEnd
        For j = 1 To 2
            resultList((i - arrStart) + 1, j) = arr(i, j)
        Next j
    Next i
    Cut_Array = resultList
End Function
Function Join_Array(arr1 As Variant, arr2 As Variant) As Variant
    Dim arr1Length As Integer
    Dim arr2Length As Integer
    arr1Length = UBound(arr1) - 1
    arr2Length = UBound(arr2)
    newArrLength = arr1Length + arr2Length
    ReDim resultList(1 To newArrLength, 1 To 2)
    For i = 1 To arr1Length
        For j = 1 To 2
          resultList(i, j) = arr1(i, j)
        Next j
    Next i
    For i = 1 To arr2Length
        For j = 1 To 2
          resultList(i + arr1Length, j) = arr2(i, j)
        Next j
    Next i
    Join_Array = resultList
End Function
Sub WriteResult(result As Variant)
    Dim Filtered As ListObject
    Set Filtered = Sheets("Filtered").ListObjects("Filtered")
    'Copy information loop
    For i = 1 To UBound(result)
        For j = 1 To UBound(result, 2)
            Filtered.Range.Cells(i + 1, j).Value = result(i, j)
        Next j
    Next i
End Sub
Sub ClearOutput()
    Dim OutputTable As ListObject
    Dim StartRow As Integer
    Set OutputTable = Sheets("Filtered").ListObjects("Filtered")
    StartRow = OutputTable.Range.Cells(1, 1).Row + 1
    If Not OutputTable.InsertRowRange Is Nothing Then
        'Pass
    Else
        Sheets("Filtered").Rows(StartRow & ":" & (OutputTable.DataBodyRange.Rows.Count + StartRow)).Delete
End Sub
jdlevinson95
I believe I got it working now. Feel free to try it out for yourself and if you do find an error I would love to know. Also, if you can think of how to simplify the code, the input would be appreciated.
;		dmax = 0
;		index = 0
;			if (d > dmax) {
;				index = i
;				dmax = d
;			# Recursive call
;		} else {
  (if
    (and ent
    ) ;and
(defun RDP (PLxyz eps end / dmax d index iter ArrRes1 ArrRes2 RecRes1 RecRes2 Res)
  (setq dmax  0.0
        index 0
    (setq d (MinDist iter PLxyz)) ;d = ShortestDistance(PointList[i], Line(PointList[1], PointList[end]))
            dmax  d ;dmax = d
    (progn
        ;# Recursive call
    (setq Res PLxyz)
) ;return Res
; PolyVert
  (vl-load-com)
) ;; return lst
;draw the polyline
  ) ;end while
;; Project Point onto Line  -  Lee Mac
;; Projects pt onto the line defined by p1,p2
(defun ProjectPointToLine (pt p1 p2 / nm)
  (setq nm (mapcar '- p2 p1)
        p1 (trans p1 0 nm)
        pt (trans pt 0 nm)
  (trans (list (car p1) (cadr p1) (caddr pt)) nm 0)
(defun MinDist (iteration ArgXYZ / pt0 pt1 pt2 pt3 dist)
  (setq pt0 (nth iteration ArgXYZ)
        pt1 (car ArgXYZ)
        pt2 (last ArgXYZ)
        pt3 (ProjectPointToLine pt0 pt1 pt2)
  (setq dist (abs (distance pt0 pt3)))
