Align UCS to segment pline in block or xref ?
Message 1 of 12
hi all
I found lisp:
(defun C:UCS3 ()
(setq ent_name (car (nentsel)))
(setq copy_of_ent (entmake (entget ent_name)))
(command "._UCS" "_Entity" (entlast))
 (entdel (entlast))
(princ)
But ucs align to start and end point. I mean align to any segment selected. Pls see file attached
how can fix it ?
Thank you.
Replies (11)
Message 2 of 12
phanaem
This works on every curve, even 3D rotated.
For non-planar curves, the Y direction is calculated accordingly to Arbitrary Axis Algorithm
;Set UCS aligned to segment
;Stefan M. - 05.08.2016
(defun c:ucsobj ( / vxs vxv mod unv v*v msg e p x y)
  (defun vxs (v s) (mapcar '(lambda (a) (* a s)) v))   ;scale vector
  (defun vxv (u v) (apply '+ (mapcar '* u v)))         ;dot_product
  (defun mod (v) (sqrt (vxv v v)))                     ;vector's module
  (defun unv (v) (vxs v (/ 1. (mod v))))               ;unit vector
  (defun v*v (a b)                                     ;cross product
    (list
      (- (* (cadr  a) (caddr b)) (* (caddr a) (cadr  b)))
      (- (* (caddr a) (car   b)) (* (car   a) (caddr b)))
      (- (* (car   a) (cadr  b)) (* (cadr  a) (car   b)))
  (if
    (and
      (setq msg "\nNothing selected.")
      (setq e (entsel))
      (setq p (osnap (cadr e) "nea"))
      (setq msg "\nInvalid object.")
      (wcmatch (cdr (assoc 0 (entget (car e)))) "LINE,SPLINE,CIRCLE,ARC,ELLIPSE,*POLYLINE")
    (progn
      (setq e (car  e)
            p (trans p 1 0)
            x (unv (vlax-curve-getfirstderiv e (vlax-curve-getparamatpoint e p)))
      (if
        (vlax-curve-isplanar e)
        (setq y (v*v (cdr (assoc 210 (entget e))) x))
        (setq y (v*v (if (< (car x) (/ 1.0 64.0)) '(0.0 1.0 0.0) '(0.0 0.0 1.0)) x))
      (command "_ucs" "_3p"
               "_non" (trans            p    0 1)
               "_non" (trans (mapcar '+ p x) 0 1)
               "_non" (trans (mapcar '+ p y) 0 1)
    (princ msg)
  (princ)
Message 3 of 12
ВeekeeCZ
Maybe using NCOPY?
(defun C:UCS3 ( / pt)
  (command "_.NCOPY" PAUSE)
  (setq pt (getvar 'lastpoint))
  (command "" "_D" '(0 0 0)
	   "_.UCS" "_Entity" (list (entlast) pt))
  (entdel (entlast))
(princ)
Message 4 of 12
scot-65
There is yet another method that does not show in the
options list of the command UCS: 3P (3 point or just 3).
>> Command: UCS
>> Current ucs name: *WORLD*
>> Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: 3
Select 2 points which represents the positive x-axis and
[Enter] for the third.
To restore, command UCS "World".
I have quick keys "UR" and "UW" to assist me.
Both are LISP and not a PGP item.
Inside these keys I turn the UCS icon On when rotating and
UCS icon Off when returning to world (2d drafting here).
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 5 of 12
 Hi phanaem,
I mean align ucs to segment pline in block. Your code use entsel then select only block.
Thanks for your solution.
Message 6 of 12
hi BeekeeCZ ^_^
NCOPY is command express, so i cannot call line (command "_.NCOPY" PAUSE)
how can fix it.
Message 7 of 12
Hi Scot,
I mean use single pick to align. It is same way "ucs" "obj" all object.
Thanks.
Message 8 of 12
Kent1Cooper
Since your example appears to be a Polyline, you may be able to modify AlignSnap.lsp with its AS command, available here.  It rotates the SNAPANG System Variable setting, rather than changing the UCS, but if that isn't enough for you, it should be easy enough to modify to do the latter instead.  It doesn't do nested entities [such as Lines within Blocks] that the (nentsel) in your example code would find.  However, a segment in a Polyline is not a "nested" entity, but part of the "main" entity, so maybe it will serve your purpose.
Never mind -- I see now from Post 5 that you are looking for nested entities.  Here's a question:  Are they always going to be straight ones?  You ought to be able to do something involving (osnap) functions applying the MID and END object snap modes at the point where you pick.
Kent Cooper, AIA
Message 9 of 12
Kent1Cooper
@Kent1Cooper wrote:
....  Are they always going to be straight ones?  You ought to be able to do something involving (osnap) functions applying the MID and END object snap modes at the point where you pick.
Such as this [minimally tested]:
(defun C:UCSN (/ esel pt)
  (if (setq esel (entsel "\nSelect straight object/nested object to align UCS with: "))
    (progn
      (setq pt (trans (cadr esel) 1 0)); put into World Coordinates
      (command "_.ucs" (osnap (trans pt 0 1) "_endpoint") (osnap (trans pt 0 1) "_midpoint") "")
    ); progn
  ); if
  (princ)
); defun
It was a little trickier than I expected -- apparently once you've given it an origin point, it reads the along-the-X-axis point you give it in relation to that new origin, which is why the routine needs to store the pick point as a WCS location, and (trans)late it into current coordinates each time.
It accepts the default on the point on the XY plane, since there are infinite possible UCS's otherwise.  But it works on either top-level or nested straight things of any variety that has mid- and endpoints to which it can Osnap.
Kent Cooper, AIA
Message 10 of 12
Very nice Kent. Smiley Very Happy
Ha ha, okey.
Thank you so much.
Message 11 of 12
scot-65
endpoint / midpoint method.
didn't think of that.
Scot-65
Message 12 of 12
Kent1Cooper
It could also use ENDpoint and NEArest, on the assumption that you're not likely to pick such a thing precisely at an endpoint and therefore get the same result from both Osnaps; or it could use MID and NEA if you don't pick it precisely at the midpoint [which seems slightly more possible, especially with Snap on].
But I am reminded of a possible issue:
If you would ever want to pick an Xline or Ray to align with, the routine would need to be built a little differently, because Xlines don't have ENDpoints and Rays don't have MIDpoints.  If the selected object is an Xline, it should use MID and NEA; if it's a Ray, it should use END and NEA.  It would count on your not picking either precisely at its origin point [which is what MID snaps to on an Xline, and END on a Ray].
Kent Cooper, AIA
