Align multiple blocks to 3Dpolyline lisp
yu85.info
Message 1 of 8
yu85.info
Hi, I have this drawing attached with many blocks. Is there a lisp to align all of them to the 3D polyline they are on it?
I founded some lisp in the web but none of them seems to work on this case of 3D polyline.
Thanks very much in advance
Replies (7)
Message 2 of 8
-didier-
Bonjour @yu85.info
These are blocks of topographical points, so I understand that you have to align the attribute not the block itself, right?
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 3 of 8
yu85.info
Yes sir you are correct
Message 4 of 8
-didier-
Bonjour @yu85.info
Here is a program for you.
It only processes one polyline at a time because I find that more efficient, we only process what we need.
If necessary, improvement is possible.
Amicalement
DA
Message 5 of 8
yu85.info
Dear sir, thank you for your hard work. Sorry for my rudeness but is it  possible to change it so it will work on multiple 3Dpolylines?
Message 6 of 8
marko_ribar
You mean like this... Untested, though...
(defun c:aliblopols ( / LM:MakeReadable s i pol ss loop n lstpar blo p dir lstpar )
  (defun LM:MakeReadable ( a )
    ;; © Lee Mac 2010
      (lambda ( a )
        (cond
          ( (and (> a (/ pi 2)) (<= a pi))
            (- a pi)
          ( (and (> a pi) (<= a (/ (* 3 pi) 2)))
            (+ a pi)
          ( t a )
      (rem a (* 2 pi))
  (prompt "\nSelect polyline entities on which you want to make block alignments readable...")
  (setq s (ssget (list (cons 0 "*POLYLINE"))))
  (repeat (setq i (sslength s))
    (setq pol (ssname s (setq i (1- i))))
    (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 "M1502_P"))))
    (if (= (logand 1 (cdr (assoc 70 (entget pol)))) 1)
      (setq loop (fix (vlax-curve-getEndParam pol)))
      (setq loop (1+ (fix (vlax-curve-getEndParam pol))))
    (setq n -1)
    (repeat loop
      (setq lstpar (cons (vlax-curve-getpointatparam pol (setq n (1+ n))) lstpar))
    (setq n -1)
    (repeat (sslength ss)
      (setq blo (ssname ss (setq n (1+ n))))
      (setq p (cdr (assoc 10 (entget blo))))
      (if (member p lstpar)
        (progn
          (setq dir (LM:MakeReadable (angle (list 0.0 0.0) (vlax-curve-getFirstDeriv pol (vlax-curve-getparamatpoint pol p)))))
          (vlax-put (vlax-ename->vla-object blo) (quote rotation) dir)
(setq lstpar nil) ) (princ) ) (prompt "\nType ALIBLOPOLS to run the topo point alignment command on a polyline(s)\n") (princ)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 7 of 8
-didier-
Bonjour @marko_ribar
Thank you for your intervention, I had not seen the request, wait to see if @yu85.info is satisfied.
Amicalement
DA
Message 8 of 8
yu85.info
Amazing!
Thank you both @-didier- @marko_ribar
