Adjust my ELEV2 attribute to middle center
etilley327KA
etilley327KA
How do I adjust my text attribute to middle center?
(defun c:TEST
  blkname clayerb clayeri clayer1 clayer2 styname htx wdy pnt-north pnt-east
  elev2Value insertionPoint pnt pluspnt elevdir *error* twistview pnt-west pnt-south
  sclx scly sclz plusymbol ADJ ELEV twistview flag 1x 1y elevdir TOC L72num L73num R72num R73num
      (defun *error* ( msg )
        (setvar "cmdecho" 1)
        (if (not (member msg '("Function cancelled" "quit / exit abort")))
            (princ (strcat "\nError: " msg))
        (princ)
  (setvar "cmdecho" 0)
  (setq
    blkname "SRVPNOC"           ; name of Block
    clayerb "-DRN"              ; defined block layer
    clayer1 "-DRNMARK"          ; attribute def #1 layer
    clayer2 "-DRNELEV"          ; attribute def #2 layer
    clayeri "-DRN"              ; inserted block layer preferably same as defined block
    styname "STANDARD"          ; text style
    htx 1                  ; attribute def height
    wdy 0.8                     ; attribute def width
    sclx 1                      ; block insert x scale factor
    scly 1                      ; block insert y scale factor
    sclz 1                      ; block insert z scale factor
    L72num 0
    L73num 3
    R72num 2
    R73num 3
  (setq twistview (getvar 'VIEWTWIST))
    (setq TOC (car (entsel "\nSelect TOC or Enter For Elevation Input: ")))
    (if (= TOC nil)
      (setq TOC (getreal "\nEnter TOC Elevation: "))
      (setq TOC (atof (getpropertyvalue TOC "ELEV2")))
  (initget "Yes No")
    (if (/= "No" (getkword "\nPlus Symbol Left? [Yes/No] <Y>: "))
      (setq plusymbol 1)
      (setq plusymbol 2)
  (setq flag 0)
   (setq ADJ 0)
  (while (/= ADJ nil)
    (setq 1x nil)
    (setq 1y nil)
    (if (= flag 1)
      (progn
        (initget "Yes No")
        (if (/= "Yes" (getkword "\nSwitch Sides? [Yes/No] <N>: "))
          (princ)
          (if (= plusymbol 1)(setq plusymbol 2)(setq plusymbol 1))
      );progn
    );if
    (setq ADJ nil)
    (setq pnt nil)
    (setq ADJ (getreal "\nEnter Elevation Adjustment: "))
    (if (/= ADJ nil)
      (progn
        (setq ELEV (+ TOC ADJ))
        (setq pnt (getpoint "\nSelect Point: "))
      (setq pnt-north (polar pnt 0.0 0.52))
      (setq pnt-east (polar pnt (/ pi 2) 0.52))
      (setq pnt-south (polar pnt pi 0.52))
      (setq pnt-west (polar pnt (* pi 1.5) 0.52))
      (setq center-point (list (/ (+ (car pnt) (car pnt-north) (car pnt-east) (car pnt-south) (car pnt-west)) 5)
                              (/ (+ (cadr pnt) (cadr pnt-north) (cadr pnt-east) (cadr pnt-south) (cadr pnt-west)) 5)))
          (if (= plusymbol 1)
            (progn
              ;---------------------------------------------------------------------------block creation------------------------
                  (entmake
                    (list
                      '(0 . "BLOCK")
                      (cons 2 blkname) ; block name
                      '(70 . 2)
                      (cons 8 clayerb)  ; layer
                      (cons 10 pnt)  ; insertion point
                      '(4 . "SRVPNOC")    ; comment
                    ) ; end of block
                ;       1=default value ; 2=Tag   ; 3=Prompt
              (entmake
                (list '(0 . "line")
                  '(100 . "AcDbEntity")
                  '(8 . "0")
                  '(100 . "AcDbLine")
                  (cons 10 pnt)
                  (cons 11 pnt-north)
              (entmake
                (list '(0 . "line")
                  '(8 . "0")
                  '(100 . "AcDbLine")
                  (cons 10 pnt)
                  (cons 11 pnt-east)
              (entmake
                (list '(0 . "line")
                  '(8 . "0")
                  '(100 . "AcDbLine")
                  (cons 10 pnt)
                  (cons 11 pnt-south)
              (entmake
                (list '(0 . "line")
                  '(8 . "0")
                  '(100 . "AcDbLine")
                  (cons 10 pnt)
                  (cons 11 pnt-west)
                    (entmake
                      (list
                        '(0 . "ATTDEF")
                        (cons 8 clayer2)                 ; layer
                        '(70 . 0)                        ; attribute flags
                        '(3 . "Elevation Value")         ; 3=Prompt
                        '(2 . "ELEV2")                   ; 2=Tag
                        (cons 1 (rtos ELEV 2 2))   ; 1=default value
                        (cons 40 htx)                    ; height
                        (cons 41 wdy)                    ; width
                        (cons 7 styname)                 ; text style
                        (cons 11 pnt) ; match insertion point
                        (cons 72 L72num)
                        (cons 73 L73num)
                    (entmake '((0 . "ENDBLK")) )       ; end of block with attdef
              ;--------------------------------------------insert----------------------------------------------
                  ; insert the block
                    (entmake
                      (list
                        '(0 . "INSERT")
                        (cons 8 clayeri)   ; layer
                        '(66 . 1)          ; has attributes
                        (cons 41 sclx)     ; x scale
                        (cons 42 sclx)     ; y scale
                        (cons 43 sclx)     ; z scale
                    ) ; begin insert Block
                    ; attrib #2
                    (entmake
                      (list
                        '(0 . "ATTRIB")
                        (cons 11 pnt)   ; insertion point
                        (cons 72 L72num)
                        (cons 73 L73num)
                    (entmake '((0 . "SEQEND")))
                    (vl-cmdf"_Rotate" (entlast) "" pnt (* -1 (* 180.0 (/ (getvar "VIEWTWIST") pi))))
            );progn
            (progn
                  (entmake
                    (list
                      '(0 . "BLOCK")
                      '(70 . 2)
                      '(4 . "SRVPNOC Value")    ; comment
                    ) ; end of block
              (entmake
                (list '(0 . "line")
                  '(8 . "0")
                  '(100 . "AcDbLine")
                  (cons 10 pnt)
                  (cons 11 pnt-north)
              (entmake
                (list '(0 . "line")
                  '(8 . "0")
                  '(100 . "AcDbLine")
                  (cons 10 pnt)
                  (cons 11 pnt-east)
              (entmake
                (list '(0 . "line")
                  '(8 . "0")
                  '(100 . "AcDbLine")
                  (cons 10 pnt)
                  (cons 11 pnt-south)
              (entmake
                (list '(0 . "line")
                  '(8 . "0")
                  '(100 . "AcDbLine")
                  (cons 10 pnt)
                  (cons 11 pnt-west)
                    (entmake
                      (list
                        '(0 . "ATTDEF")
                        (cons 72 R72num)
                        (cons 73 R73num)
                  ; insert the block
                    (entmake
                      (list
                        '(0 . "INSERT")
                    ; attrib #2
                    (entmake
                      (list
                        '(0 . "ATTRIB")
                        (cons 72 R72num)
                        (cons 73 R73num)
            );progn
          );if
        (setq flag 1)
      );progn
    );if
  );while
  (princ) ; end insert block
CodeDing
paullimapa
@CodeDing provided you an excellent link
notice that attrib & attdef unlike text don't use group code 73 but instead 74
for middle center, 72 = 1 & 74 = 2
Paul Li
IT Specialist
@The Office
Village_Idiot
Try (74 . 2)
etilley327KA
Sweet, is there any way to add space between the insertion and the attribute using those DXFs? My screen is twisted, so using the X puts it off.
