add a block in a block
etilley327KA
etilley327KA
How do add a block as an attribute for another block?
Im trying to add "block-name" to this block.
                  (entmake
                    (list
                      '(0 . "BLOCK")
                      (cons 2 blkname) ; block name
                      '(70 . 2)
                      (cons 8 clayerb)  ; layer
                      (cons 10 pnt)  ; insertion point
                      '(4 . "SRVPNOC")    ; comment
                    ) ; end of block
                ;       1=default value ; 2=Tag   ; 3=Prompt
                    (entmake
                       (list
                         '(0 . "ATTDEF")
                         (cons 8 clayer1)           ; layer
                         '(70 . 0)                  ; attribute flags (non-constant, invisible, doesn't lock)
                         (cons 3 "")                   ; 3=Prompt (empty string)
                         (cons 2  block-name)              ; 2=Tag (attribute tag)
                         (cons 1 "") ; 1=default value (attribute value)
                         (cons 40 htx)               ; height
                         (cons 41 wdy)               ; width
                         (cons 11 pnt)      ; match insertion point
                         '(72 . 0)                   ; 0=10 as insertion point
                    (entmake
                      (list
                        '(0 . "ATTDEF")
                        (cons 8 clayer2)                 ; layer
                        (cons 10 elevdir)   ; insertion point
                        '(3 . "Elevation Value")         ; 3=Prompt
                        '(2 . "ELEV2")                   ; 2=Tag
                        (cons 1 (rtos ELEV 2 2))   ; 1=default value
                        (cons 7 styname)                 ; text style
                        (cons 11 elevdir) ; match insertion point
                    (entmake '((0 . "ENDBLK")) )       ; end of block with attdef
                  ; insert the block
                    (entmake
                      (list
                        '(0 . "INSERT")
                        (cons 8 clayeri)   ; layer
                        '(66 . 1)          ; has attributes
                        (cons 41 sclx)     ; x scale
                        (cons 42 sclx)     ; y scale
                        (cons 43 sclx)     ; z scale
                    ) ; begin insert Block
                    ; attrib #1
                    (entmake
                       (list
                         '(0 . "ATTDEF")
                    ; attrib #2
                    (entmake
                      (list
                        '(0 . "ATTRIB")
                        (cons 11 elevdir)   ; insertion point
                    (entmake '((0 . "SEQEND")))
Kent1Cooper
I don't think a Block can be an Attribute in another Block.  It can be an object in the other Block's definition, just as a Line or a Circle can be -- a nested Block.
Kent Cooper, AIA
etilley327KA
So do I just change "ATTDEF" to "BLOCK"?
Kent1Cooper
No, because an ATTDEF has properties/DXF entries that a Block does not, like Tag and Prompt and various Text properties.  I don't have experience with (entmake)ing Blocks, but my guess is that it would need to be an "INSERT" object inside the outer Block's definition, because to do it manually you would Insert the nested Block.
Kent Cooper, AIA
ronjonp
@etilley327KA
How many of these blocks do you need to make? If not too many, I've found it much easier to use a template with them already defined.
