Adding Second Atribute to Inserted Block
Message 1 of 13
I have a LISP that someone wrote on here a little while ago (thanks again!) that would allow a user to import a .csv file, and from that file take a point name, then the x,y,z coordinates and place the block in automatically.
I need to modify that lisp and add a second attribute name.
I tried adding a second ATT expression but it did not seem to accept it.
Any hints on where and how a couple of lines should be added (see attached)?
Replies (12)
Message 2 of 13
pbejse
If you know the TAG names you can do it this way
(defun c:I-MW (/ fn fp lst l)
  (setq fn (getfiled "Select CSV file" "" "csv" 4))
  (setq	fp  (open fn "r")
	lst '()
  ) ;_ end of setq
  (while (setq l (read-line fp))
    (setq lst (cons l lst))
  ) ;_ end of while
  (close fp)
  (setq VAL (getvar "attreq"))
  (command "attreq" 0)
  (foreach Row lst
    (while (if (setq n (vl-string-search "," Row 0))
		     (setq Row (vl-string-subst " " "," Row))
		   ) ;_ end of if
    ) ;_ end of while
    (setq Row (read (strcat "(" Row ")")))
    (setq ATT1 (vl-symbol-name (nth 0 Row)))
    (setq X (nth 1 Row))
    (setq Y (nth 2 Row))
    (setq Z (nth 3 Row))
    (setq PT1 (list X Y Z))
    (command "insert" "monitoring_well" PT1 "1" "" "")
    (setq bl (entlast))
    	(setpropertyvalue bl "ATT1" ATT1)
    	(setpropertyvalue bl "ATT2" "AnotherValue")
  ) ;_ end of foreach
  (command "attreq" VAL)
Message 3 of 13
cadffm
To show how it works in the way your program works now,
look at this (pbejse answer is a good one, but i like also to show this / for a better understanding of your original code).
Original
(defun c:I-MW ( / fn fp lst l)
(setq fp (open fn "r") lst '())
(close fp)
(command "attreq" 0) ;; <-- disable the question about attributvalues
(foreach Row lst
(setq b1 (entget (entnext (entlast)))) ; <-- take the blockreference
(setq ff1(assoc 1 b1))
(setq xx1 (cons 1 ATT1))
(entmod(subst xx1 ff1 b1))
Var1
(defun c:I-MW ( / fn fp lst l VAL DAL n row x y z ATT1 PT1)
(close fp)
(setq DAL (getvar "attdia")) ;; <--Thats also good for your original code! Att dialogwindow, or not..
(command "attreq" 1) ;; <-- enable the question about attributvalues
(command "attdia" 0) ;; <-- disable the question about attributvalues
(foreach Row lst
(and
(command "insert" "monitoring_well" PT1 "1" "" "" ATT1)
);_and
(command "attreq" VAL "attdia" DAL)
;; Start the command -INSERT to see whats going on inside your "(command ..)"
Sebastian
Message 4 of 13
pbejse
look at this
Agreed, thats makes a lot more sense 👍
(command "insert" "monitoring_well" PT1 "1" "" "" ATT1 ATT2 ATT3 ...) ;< as many as you need
Message 5 of 13
cadffm
Oups
(command "attdia" 0) ;; <-- change the dialog window version to the commandline version (when Acad ask for  attributvalues)
Sebastian
Message 6 of 13
Thanks for your reply.
One item I didn't ask about is what column within the .csv file would the Lisp use for the second attribute? How is that specified?
I haven't tried your changes yet but will shortly pending the question above.
Message 7 of 13
Are you suggesting everything under Var1 should be the new code rather than just change for the comments in the original code?
Message 8 of 13
hak_vz
In code you have this:
You have to decide how you want to add attribute value to .csv file
Placement inside a row is not important as long as you know which element in row list will be assigned to particular variable. Elements inside list are counts starting from 0.
One option is
(setq ATT2 (vl-symbol-name (nth 1 Row)))
(setq X (nth 2 Row))
(setq Y (nth 3 Row))
(setq Z (nth 4 Row))
Miljenko Hatlak
Message 9 of 13
cadffm
I am not sure if my code works well, i just pointet to the important part of your question,
you posted an incomplete package what cannot be easily tested..
in this cases do not all what is possible for me, because it isn't my job 😉
Upload complete sample (code, DWG with your blocks ad one csv file), then it is easy to test and to help you with your problems,
otherwise we have unnecessary  work with it (and it isn't our problem).
Sebastian
Message 10 of 13
Thanks for the response.
This adds clarity as the second attribute is the same as the first attribute for my applicaiton and I can make them the same row. As strange as that sounds I am adding 'halo' blocks on maps where the background attribute is white (as well as larger than the top attribute) and has the same value as the attribute above it in order for it to show better on a map image.
Message 11 of 13
I tried that and it seems t be getting caught up in an "attreq" point.
I have attached the code for a BH-Halo insertion with the changes and additions as far as I know.
The block and .csv are also attached.
Message 12 of 13
pbejse
If you already setup the the correct values for both ATTDIA and ATTREQ, then you dont need this lines anymore.
    (setq ff1 (assoc 1 b1))
    (entmod (subst xx1 ff1 b1))
as stated at post #4
(defun c:I-BH-Halo (/ fn fp lst l)
	lst '()
  ) ;_ end of setq
  ) ;_ end of while
  (close fp)
  (foreach Row lst
	   ) ;_ end of if
    ) ;_ end of while
    (setq ATT2 (vl-symbol-name (nth 0 Row)))
    (command "insert" "BH-Halo" PT1 "1" "" "" ATT1 ATT2)
  ) ;_ end of foreach
) ;_ end of defun
Message 13 of 13
Thanks 'pbelse'.
I'm more than a little rusty with My LISP these days.
