Adding a code to this lisp that brings in a title block and changes its viewname value to match the pdfs being selected
fabi_rm94
fabi_rm94
Hello!
Im working on a lisp and want to add a code section that brings in a detail title block (the block would already exist in the drawing, so copying it and pasting it would not be a problem) and places it in any page where I'm inserting a pdf xref. Now, the interesting part is that I would want, if possible, for the value of the title block to change to the name of the pdf Im selecting to open in that particular page/layout tab. Is there any way you guys can conceive doing that?
EX: I run the below code, and I select to insert the pdf called "large gallon tank", I'd then want the code to insert a block called "DETL_TITLE" at "6.0, 0.75", scale "1" and have the name attribute of that block change to "large gallon tank".
BUPSUP(defun c:BUPSUP ( / )
	(c:BUPSUP)
(defun c:BUPSUP
		; Functions
			MN:ListBox _PDFPageCount findEmptySlot IncrementSheet ClearSheet
		;Variables
			dir lst mfr specs inspts pt scl pages page_lst cur_layout
	(cb:writetotext "networks" "SPCI")
	(vl-load-com)
	(defun MN:ListBox ( title lst bit / *error* dch des tmp res )
		(defun *error* ( msg )
			(if (< 0 dch)
				(unload_dialog dch)
			(if (= 'file (type des))
				(close des)
			(if (and (= 'str (type tmp)) (setq tmp (findfile tmp)))
				(vl-file-delete tmp)
			(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
				(princ (strcat "\nError: " msg))
			(princ)
		(cond
				(not
					(and
						(setq tmp (vl-filename-mktemp nil nil ".dcl"))
						(setq des (open tmp "w"))
						(write-line
							(strcat
								"listbox : dialog
									label = \"" title "\";
									spacer;
									: list_box
										key = \"list\";
										multiple_select = " (if (null bit) "false" "true")";
									width = 50;
									fixed_width = true;
									spacer;
									ok_cancel;
							des
						(not (close des))
						(< 0 (setq dch (load_dialog tmp)))
						(new_dialog "listbox" dch)
				(prompt "\nError loading list box.")
			( 1
				(start_list "list")
				(foreach item lst (add_list item))
				(end_list)
				(setq res (set_tile "list" "0"))
				(action_tile "list" "(setq res $value)")
				(setq res
					(if (= 1 (start_dialog))
						(mapcar '(lambda ( x ) (nth x lst)) (read (strcat "(" res ")")))
		(if (< 0 dch)
			(setq dch (unload_dialog dch))
		(if (not (null res))
			res
			nil
	(defun _PDFPageCount ( filename / fob fso mat reg res str )
		(if
			(and
				(setq filename (findfile filename))
				(eq ".PDF" (strcase (vl-filename-extension filename)))
			(vl-catch-all-apply
				(function
					(lambda ( / _ReadAsTextFile _CountPage )
						(defun _ReadAsTextFile ( fso fn / fob str res )
							(setq
								fob (vlax-invoke fso 'getfile fn)
								str (vlax-invoke fso 'opentextfile fn 1 0)
								res (vlax-invoke str 'read (vlax-get fob 'size))
							(vlax-invoke str 'close)
							(vlax-release-object str)
							(vlax-release-object fob)
							res
						(defun _CountPage ( rgx str / mat pag )
							(vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]")
							(vlax-put-property rgx 'ignorecase actrue)
							(vlax-put-property rgx 'global actrue)
							(setq
								mat (vlax-invoke rgx 'execute str)
								pag (vlax-get mat 'count)
							(vlax-release-object mat)
							(if (zerop pag) 1 pag)
						(setq
							fso (vlax-create-object "Scripting.FileSystemObject")
							reg (vlax-create-object "VBScript.RegExp")
							str (_ReadAsTextFile fso filename)
							res (_CountPage reg str)
		(foreach obj (list str fob mat fso reg)
			(vl-catch-all-apply 'vlax-release-object (list obj))
		res
	;; Translation by Lee Mac of the VBScript code by Chanh Ong
	;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script
	;; Call with fully qualified filename of PDF file:
	;; (_PDFPageCount "C:\\Folder\\Filename.pdf")
	;; Returns integer describing number of pages in specified PDF file
	(defun findEmptySlot ( lst / i ent nums )
		;; CONVERT LST "1.009,2.869,3.14" -> (LIST 1.009 2.869 3.14)
		(setq i 0)
		(cond
			((eq 'STR (type (nth i lst)))
				(setq nums (mapcar '(lambda (x y) (cons (atof (substr x 1 (vl-string-search "," x))) (atof (substr y (+ (vl-string-search "," y) 2))))) lst lst))
				(while (and (setq ent (nentselp "" (list (car (nth i nums)) (cdr (nth i nums))))) (/= i (1- (length lst))))
					;(vl-remove-if-not '(lambda (x) (wcmatch x "*R-*")) (layoutlist))
					(setq i (1+ i))
				(if (null ent)
					(nth i lst)
	(defun ClearSheet ( ss / ind ent )
		(repeat (setq ind (sslength ss))
			(setq
				ind (1- ind)
				ent (ssname ss ind)
			(entdel ent)
		(princ)
	; [SS] SELECTION SET
	; CLEARS OUT ALL ENTITIES PASSED AS SELECTION SET [SS]
	(defun IncrementSheet ( sht / sht+ )
		(setq sht+
			(strcat
				(substr sht 1 (1+ (vl-string-search "-" sht)))
				(rtos (1+ (atoi (substr sht (+ (vl-string-search "-" sht) 2)))) 2 0)
	;;; MAIN ;;;
	(setq dir "C:\\_Vault\\ATC\\DAS\\_DAS Library\\BUP Supplementals")
	(if (not (vl-file-directory-p dir))
		(princ (strcat "Directory: " dir "\nNot found.\nPlease download/'GET' this location from Vault."))
		(progn
			(setq lst (vl-remove-if '(lambda (x) (and (member x (list "." ".." "_V")))) (vl-directory-files dir nil -1)))
			(if
				(and
					(setq mfr (car (MN:ListBox "Select Generator Manufacturer:" lst nil)))
					(setq specs (MN:ListBox "Select Generator Spec Sheet(s):" (vl-directory-files (strcat dir "\\" mfr) "*.pdf*" 1) 1))
				(progn
					(setq
						inspts (list
									"0.60475,1.38142"
									"7.42514,1.38142"
						scl "0.77272727"
					(if (vl-catch-all-error-p (vl-catch-all-apply 'setvar (list "CTAB" "R-601")))
						(princ "\nError.\nLayout tab 'R-601' does not exist.")
						(foreach spec specs
							;(command-s "PDFATTACH" (strcat dir "\\" mfr "\\" spec))
							(setq pages (_PDFPageCount (strcat dir "\\" mfr "\\" spec)))
							(setq page_lst nil)
							(repeat pages
								(setq page_lst (cons (rtos pages 2 0) page_lst))
								(setq pages (1- pages))
							(setq page_lst (MN:Listbox (strcat "Select " spec " sheet(s):") page_lst 1))
							(foreach p page_lst
								(setq cur_layout (getvar "CTAB"))
								(while
									(not
										(cond
											((setq pt (findEmptySlot inspts))
												; insertion point or nil
												T
											((vl-catch-all-error-p (vl-catch-all-apply 'setvar (list "CTAB" (setq cur_layout (IncrementSheet (getvar "CTAB"))))))
												; T or nil
												(command "_.LAYOUT" "C" (getvar "CTAB") cur_layout)
												(setvar "CTAB" cur_layout)
												(ClearSheet (ssget "C" '(0.60475 9.88142) '(13.9933 1.38142)))
								(command "-PDFATTACH" (strcat dir "\\" mfr "\\" spec) p pt scl "0.0" nil)
								(setq pt nil)
				(princ "\nFunction canceled")
	(princ)
Attached is the lisp code and the template to help with context. Feel free to set the setq dir "C:\\_Vault\\ATC\\DAS\\_DAS Library\\BUP Supplementals" to any location to test the code with any pdf
Thanks!
fabi_rm94
Bump!
fabi_rm94
Anybody got any ideas for this request??
Sea-Haven
I did not do any code but if you know name of pdf, when you copy a layout you can get the title block in that layout.
(setq ss (ssget "X" '((0 . "INSERT")(2 . "yourblockname")(cons 410 (getvar 'ctab)))))
So you have the title block and if its the only 1 in that layout. Then you can get the attributes and change the correct one to your pdf name.
