Add + sign to altitude/height of number text
jocke.o92
Message 1 of 9
jocke.o92
Hello
I got a 3d application that I export survey points of elevation to Autocad file. I export height and code. When exporting this heights the text is ex 24.001 and if it is under 0.00 it will print it out with a "-" like -24.001. So all negative elevations get a "-" infront of the height text but heights above 0 doesn't get a "+" sign.
For most of the cases this work fine and there is no need to seperate them with the +, but sometime I need write out the + sign i front of all elevation above 0. This takes time to do i manually.
So my question is, if there is a way to add a "+" sign to all z-values that are above 0? I have talked to the support of the 3d application and there is nog option to add + sign in export to dwg.
And also if this could be applied to all text, Mtext, multileader and text?
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
Can you share a sample DWG file with these entries in them?
Message 3 of 9
jocke.o92
Here is an example
Message 4 of 9
hak_vz
Try this
(defun c:plus_sign_elev ( / ss o eo val)
(setq ss (ssget '((0 . "TEXT")(8 . "VG*"))) i -1)
(while (< (setq i (1+ i))(sslength ss))
(setq eo (vlax-ename->vla-object (ssname ss i)))
(setq val (atof (vla-get-textstring eo)))
(if (> val 0.0) (vlax-put eo 'TextString (strcat "+" (vla-get-textstring eo))))
(vla-Regen (vla-get-ActiveDocument (vlax-get-acad-object)) acAllViewports)
(princ)
Miljenko Hatlak
Message 5 of 9
3wood
You can also try ALTEXT to add prefix "+" in front of select numbers great than 0.00.
Message 6 of 9
jocke.o92
This works perfect!
Message 7 of 9
jocke.o92
I tried this to and it works good :)!
Message 8 of 9
hak_vz
@jocke.o92 wrote:
This works perfect!
Glad to be of help! You have to be careful when using this script. It will collect all text entities from any layer whose name starts with "VG", In some other circumstances you will have to change selection filter. But if layer names are standard then this simple script will work without error. You can add this to your autolisp startup suite or assign to menu button.
Miljenko Hatlak
Message 9 of 9
pbejse
(defun c:symbiotic (/ ss i e zed str)
  (if
    (setq ss (ssget '((0 . "MTEXT,TEXT"))))
     (repeat (setq i (sslength ss))
       (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
       (setq zed (last (vlax-get e 'Insertionpoint)))
       (setq str (vlax-get e 'Textstring))
       (if
	 (numberp (read str))
	 (vlax-put e
		   'Textstring
		   (strcat (if (minusp zed)  ""  "+" )
			   (rtos zed 2)
  (princ)
