- Mute
- Permalink
- Report
Hello
I got a 3d application that I export survey points of elevation to Autocad file. I export height and code. When exporting this heights the text is ex 24.001 and if it is under 0.00 it will print it out with a "-" like -24.001. So all negative elevations get a "-" infront of the height text but heights above 0 doesn't get a "+" sign.
For most of the cases this work fine and there is no need to seperate them with the +, but sometime I need write out the + sign i front of all elevation above 0. This takes time to do i manually.
So my question is, if there is a way to add a "+" sign to all z-values that are above 0? I have talked to the support of the 3d application and there is nog option to add + sign in export to dwg.
And also if this could be applied to all text, Mtext, multileader and text?
