Add Incremental Value to Numerical Text
codee
codee
There are posts on this forum about this. Not one LISP routine I have found works.
Is there a routine where I can select multiple numerical text and then enter a positive or negative number to add to them, and then set the precision, and have it replace the original text?
Thank you if you know of one that you can share.
pendean
Community Legend
Community Legend
Post examples please.
ВeekeeCZ
THIS NumInTxt routine by CADStudio might be too complex for your task, but it definitely works.
See the example HERE
codee
Example... I have text "5.50" and "4.75" I want to select both of them and add 1.1 to both so that I have "6.60" and "5.85"
Kent1Cooper
You don't say which ones you've tried.  Did they include EDITNUM.lsp from @john.uhden , >here<?  In quickie trial, it seems to honor the precision of each original number, but I think if you want all to be at the same precision whatever the original had, you could probably just change all instances of the  |prec  and  |cprec  and possibly  |dec  variables [the precision arguments in (rtos) functions generating the new text content] to your desired number of decimal places.
Kent Cooper, AIA
john.uhden
Thanks, Kent.
That's a great way of providing an explanation without jerking around with
code (by either you or me).
John F. Uhden
3wood
You can also try ALTEXT.
