Add if statement to give me a choice of which data file to set
johnw
Message 1 of 10
johnw
In the code below I don't know where I should insert an IF statement that when I execute this command it will prompt me "Is this set of layers for std or custom:". If std, which would be the default, it would follow the layerset.dat coding that is already listed. If Custom, type "C" for custom and then it would load, read, a file called layerset1.dat instead. Nothing else would need to change. Thanks for any assistance.
(defun C:LAYERSET ()
    (command "redraw")
    (SETVAR "REGENMODE" 0)
    (COMMAND-S "LAYER""SET""0""")
    (COMMAND-S "LAYER""FREEZE""*""")
    (prompt "Installing new layers:  ")
    (terpri)
    (prompt "          please wait....")
    (SAVEMODE
        (quote
            ("CMDECHO" "MENUECHO" "EXPERT")
    (setvar "EXPERT" 0)
    (setvar "CMDECHO" 0)
    (setvar "MENUECHO" 3)
    (setq RFILE (OPEN (strcat lisp "layerset.dat") "r")) ;Opens layerset.dat for read
    (setq LAYER (read-line RFILE))
    (setq LINETYPE (read-line RFILE))
    (setq COLOR (read-line RFILE))
        (while (/= LAYER nil)
            (command "LAYER" "m" LAYER "lt" LINETYPE LAYER "c" COLOR LAYER "");if linetype does not exist, then, this will be interrupted in the middle
    (command ^C^C)
        )                                              ;end while
    (close RFILE)
    (terpri)
   (SETVAR "REGENMODE" 1)
   (COMMAND "LAYER""THAW""*""")
   (RESTMODE)
    (prompt "\nAll the Layers, Colors, and Linetypes are installed or have been reinstalled....")
    (prin1)
Replies (9)
Message 2 of 10
john.uhden
Hello, @johnw , I am JohnU.
First, I'm gonna guess that your .DAT file contains multiple layers and properties.  So you may want to structure your program something like this:
 (while (setq line (read-line RFILE))
   (if (not (tblsearch "ltype" linetype))
     (setq linetype "Continuous") ;if linetype does not exist
Of course I would prefer to include the layer, linetype. and color as one line in the file, each property delimited.  by a tab.  Otherwise, if you miss a line or add an extra one, then your sequence will be lobotomized.  If you're interested in that method then I (or dozens of others) will provide you a function to do that.
Always remember to close the file.
John F. Uhden
Message 3 of 10
paullimapa
I would change the code at this point:
to this:
; dynmode needs to be 1 or 3 to display cursor popup
(if(<= (rem (getvar"dynmode") 2) 0) ; if even # chks negative value as well
  (progn
   (setq dynmode (getvar"dynmode")) ; save current setting
   (setvar "dynmode" 1) ; enable dynmode
) ; if
(or **lyropt** (setq **lyropt** "Standard")) ; setup default
(initget (setq lyropt "Standard Custom"))
(setq **lyropt** (cond ((getkword (strcat "\nIs this set of layers for [" (vl-string-translate " " "/" lyropt) "] <" **lyropt** ">: ")))(**lyropt**)))
(if dynmode (setvar "dynmode" dynmode)) ; restore original dynmode setting
(if (eq **lyropt** "Standard")
 (setq lyrfile "layerset.dat")
 (setq lyrfile "layerset1.dat")
(setq RFILE (OPEN (strcat lisp lyrfile) "r")) ;Opens layer file to read
Paul Li
IT Specialist
@The Office
Message 4 of 10
komondormrex
acet used.
    (command "redraw")
    (terpri)
    (SAVEMODE
        (quote
    (setvar "EXPERT" 0)
	(if (= 6 (acet-ui-message "Are you going to process STD Layer set?" "Attention" 4))
			(setq RFILE (OPEN (strcat lisp "layerset1.dat") "r")) ;Opens layerset1.dat for read
    (command ^C^C)
        )                                              ;end while
    (close RFILE)
    (terpri)
   (RESTMODE)
    (prin1)
Message 5 of 10
johnw
Thanks for your help on this! I really appreciate it!
Message 6 of 10
WeTanks
please teach me
Why is it an error?
    (command "redraw")
			(setq RFILE (OPEN (strcat "D:\\OneDrive\\11_LISP_FORUM\\layerset.dat") "r")) ;Opens layerset.dat for read
			(setq RFILE (OPEN (strcat "D:\\OneDrive\\11_LISP_FORUM\\layerset1.dat") "r")) ;Opens layerset1.dat for read
English is my second language.
Please don't worry if I make any English mistakes.
英語は母国語ではない
英語のミスをしても気にしないでください。
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 7 of 10
john.uhden
@WeTanks ,
You appear to be using strcat with only one string.
John F. Uhden
Message 8 of 10
WeTanks
This is my all LISP. I just modified that part of dat.
    (command "redraw")
    (terpri)
    (SAVEMODE
        (quote
    (setvar "EXPERT" 0)
    (command ^C^C)
        )                                              ;end while
    (close RFILE)
    (terpri)
   (RESTMODE)
    (prin1)
We.Tanks
図面一括印刷
Message 9 of 10
komondormrex
it is undeclared 'savemode' function which your code tries to execute in line 9. you need to load it before running your code.
and as @john.uhden  wrote it is better to remove 'strcat' function for concatenating the only string. however the code will still be running with it.
or you can add these functions to your code or load them independently.
(defun savemode (var_list)
	(setq savemode_remembered (mapcar 'cons var_list (mapcar 'getvar var_list)))
	(princ)
(defun restmode nil
	(mapcar '(lambda (var_data) (setvar (car var_data) (cdr var_data))) savemode_remembered)
	(princ)
Message 10 of 10
WeTanks
どうもありがとうございました。
We.Tanks
図面一括印刷
