ACISOUT with vla-sendcommand
EnM4st3r
EnM4st3r
Hi, I try to use ACISOUT on another drawing, wich im opening with my lisp.
Here is the code i have:
(defun c:test123 (/ doc)
  (setq doc (myOpen "Z:\\Temp\\Drawing3.dwg"))
  (vla-sendcommand doc "(command \"ACISOUT\" \"_all\" \"\" (getfiled \"Save file\" \"\" \"sat\" 1)) ")
  (princ)
(defun myOpen (filename) ;opens drawing
  (vla-open
    (vla-get-documents (vlax-get-acad-object))
    filename
    (if (fileOpenp filename)
      :vlax-true
      :vlax-false
(defun fileOpenp (file / f) ; cecks if file is Opened
  (if (setq f (open file "a"))
    (close f)
    t
);defun
 Problem is this line is not working:
i have also tried  using getfiled before vla-sendcommand and then put it together like a script within vla-sendcommand wich looked like this but also didnt work correctly.
(defun c:test123 (/ *error* filedia doc file)
  (defun *error* (msg)
    (if filedia (setvar "Filedia" filedia))
    (princ (strcat) "Error: " msg)
    (princ)
  (setq fieldia (getvar "filedia"))
  (setvar "filedia" 0)
  (setq file (getfiled "Save file" "" "sat" 1))
  (vla-sendcommand doc (strcat "ACISOUT " "_all  " file " "))
  (setvar "filedia" filedia)
  (princ)
EnM4st3r
ok im just using insert now.. much easier than doing stuff in a new drawing
