acad.lsp
acad.lsp
ScottBolton-67
902件の閲覧回数
18件の返信
メッセージ1/19
acad.lsp
ScottBolton-67
Hi, chaps.
I have the code,
(strcat "C:\\Users\\" (getvar "USERNAME") "\\blue\\...")
in my acad.lsp but it gives the error,
Regenerating model.
; error: bad argument type: (or stringp symbolp): (STRCAT "C:\\Users\\" (GETVAR "USERNAME") "\\blue\\...")
AutoCAD menu utilities loaded.
at startup.
Anybody know why? (I also tried using (getenv) but got the same (or stringp symbolp) error.)
0 件のいいね
解決済み
903件の閲覧回数
18件の返信
返信 (18)
メッセージ2/19
paullimapa
no such variable called username
but username is an environment variable
so change the code to:
(strcat "C:\\Users\\" (getenv "USERNAME") "\\blue\\...")
Paul Li
IT Specialist
@The Office
0 件のいいね
メッセージ3/19
Kent1Cooper
There is no "username" System Variable.
Kent Cooper, AIA
0 件のいいね
メッセージ4/19
pendean
Community Legend
Community Legend
Give them a try at the commandline, they report my OS login name here in AutoCAD 2023-2025 (but only LT versions HELP list is as a variable)
(getenv "USERNAME")
(getvar "USERNAME")
USERNAME
0 件のいいね
メッセージ5/19
pendean
Community Legend
Community Legend
@ScottBolton-67 What is it you are trying to do or activate or show with that exactly?
0 件のいいね
メッセージ6/19
pkenewell6347
Have you tried pasting the line directly to the command line? It works correctly for me. What version of AutoCAD are you using?
0 件のいいね
メッセージ7/19
pendean
Community Legend
Community Legend
@pkenewell6347 wrote:
...It works correctly for me....
Works how? To do what? All I get at the comamndline is
"C:\\Users\\MYLOGINNAMEHERE\\blue\\..."
0 件のいいね
メッセージ8/19
pkenewell6347
0 件のいいね
メッセージ9/19
pkenewell6347
It seems to me that the OP is trying to find their profile folder in windows? I don't know. All I was doing was confirming it worked in my system (AutoCAD 2025), and trying to figure out why it was not working for the OP. Perhaps he is using a much older version of AutoCAD? Maybe the install is corrupted? I wasn't trying to determine what he was doing, just whether it should work or not.
0 件のいいね
メッセージ10/19
paullimapa
Though username may exists as system variable in LT, there was no lisp back in 2020...only staring in 2024LT.
But as for AutoCAD the username system variable did not exist prior to 2023.
So older versions would yield this error:
Perhaps @ScottBolton-67 OP encountered this error when trying to load acad.lsp in versions prior to 2023?
Paul Li
IT Specialist
@The Office
メッセージ11/19
pendean
Community Legend
Community Legend
@paullimapa wrote:
Though username may exists as system variable in LT, there was no lisp back in 2020...only staring in 2024LT...
LT versions of AutoCAD have always had a USERNAME variable, it used to reside in OPTIONS as an item you could enter until it was changed in the last decade to capture the user's OS log-in instead. It has nothing to do with the introduction of LISP into LT. Came in handy back when using the PLOTSTAMP on all plots to be user and department specific for those of us that need it.
Good point on pre-2023 full AutoCAD, I no longer run anything older to have checked it there.
0 件のいいね
メッセージ12/19
ScottBolton-67
So, we've established that (getvar "USERNAME") is valid and it yields the same result as (getvar "LOGINNAME").
On the command line, or in the VL Console, both
(strcat (getenv "UserProfile") "\\sbTOOLS\\...") and
(strcat "C:\\Users\\" (getvar "USERNAME") "\\sbTOOLS\\...")
yield the same result: "C:\\Users\\NLA417\\sbTOOLS\\..." in my case.
The problem arises when it is run from the acad.lsp file:
; error: bad argument type: (or stringp symbolp): (STRCAT (GETENV "UserProfile") "\\sbTOOLS\\...") and
; error: bad argument type: (or stringp symbolp): (STRCAT "C:\\Users\\" (GETVAR "USERNAME") "\\sbTOOLS\\...")
I want it loading here because I add that location, sbTOOLS, to my TRUSTEDPATHS,
(setvar "TRUSTEDPATHS" (strcat bT_paths ";" bT_nth))
0 件のいいね
メッセージ13/19
paullimapa
as a test lets try a different system variable and see if you get a successful response:
(STRCAT "C:\\Users\\" (GETVAR "ctab") "\\sbTOOLS\\...")
Paul Li
IT Specialist
@The Office
0 件のいいね
メッセージ14/19
pkenewell6347
Interesting. Question: Do you just run it from acad,lsp, or do you have it within an "S::STARTUP" defun? Perhaps the system variable has not initialized. If you put it in an "S::STARTUP" defun, it waits until last after everything initializes. Also - you should be using acaddoc.lsp instead of acad.lsp if you want this to load in every dwg file.
Look at this for more info (scroll down a bit for info on S::STARTUP, but I recommend reading the whole thing):
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-FDB4038D-1620-4A56-8824-D37729D42520
メッセージ15/19
Kent1Cooper
@pendean wrote:...
I am currently at an Acad2020 [full vanilla] installation, where (getvar "USERNAME") returns nil.
Kent Cooper, AIA
メッセージ16/19
ec-cad
R2021 vanilla.
(getvar "USERNAME") ; returns nil
(getvar "LOGINNAME") ; returns my name
ECCAD
0 件のいいね
メッセージ17/19
Sea-Haven
Bricscad V24, (getvar "LOGINNAME") ; returns my name
0 件のいいね
メッセージ18/19
ScottBolton-67
解決済み
Thanks for the S::STARTUP tip.
I run it from the acad.lsp, but if I put it in acaddoc.lsp instead it runs fine.
メッセージ19/19
Sea-Haven
Just a comment I never touch acad & acaddoc.lsp rather use appload and add a custom lisp to the start up suite. I find this easier as the custom lisp is saved with my other lisps. When you do an upgrade just redo the appload, no go searching for acaddoc.
0 件のいいね
