I was trying to create a lisp program to get the results using numbers from the text.
formulae is y=x-kd where,
x & d are extracted from the two different texts and value of k is as user input. I was able to get the values correct on command line. But unable to insert it as a text entity. I am getting an error called,
error: bad DXF group: nil
code is given below. Can someone please help me with it ?
(defun c:calculateY (/ xText dText k x d y xEnt dEnt entdata insertionPoint textHeight textStyle)
;; Prompt the user to select the text entity containing the value of x
(setq xEnt (car (entsel "\nSelect text entity containing the value of x: ")))
;; If a valid entity is selected for x
(if (and xEnt (eq (cdr (assoc 0 (entget xEnt))) "TEXT"))
(progn
(setq xText (cdr (assoc 1 (entget xEnt))))
(setq x (atof xText))
(progn
(princ "\nInvalid selection for x. Please select a text entity.")
(exit)
;; Prompt the user to select the text entity containing the value of d
(setq dEnt (car (entsel "\nSelect text entity containing the value of d: ")))
;; If a valid entity is selected for d
(if (and dEnt (eq (cdr (assoc 0 (entget dEnt))) "TEXT"))
(progn
(setq dText (cdr (assoc 1 (entget dEnt))))
(setq d (atof dText))
(progn
(princ "\nInvalid selection for d. Please select a text entity.")
(exit)
;; Prompt the user for the value of k
(setq k (getreal "\nEnter the value of k: "))
;; Calculate the value of y if x, d, and k are valid
(if (and x d k)
(progn
(setq y (- x (* k d)))
(princ (strcat "\nThe value of y is: " (rtos y 2 2)))
;; Get text height and style from x text entity
(setq textHeight (cdr (assoc 40 (entget xEnt))))
(setq textStyle (cdr (assoc 7 (entget xEnt))))
;; Ensure textHeight and textStyle are valid
(if (and textHeight textStyle)
(progn
;; Prompt for the insertion point of the new text
(setq insertionPoint (getpoint "\nSpecify insertion point for new text: "))
;; Ensure insertionPoint is valid
(if insertionPoint
(progn
(setq newText (rtos y 2 2))
(entmake (list (cons 0 "TEXT")
(cons 10 insertionPoint)
(cons 1 newText)
(cons 40 textHeight)
(cons 7 textStyle)
(cons 8 (cdr (assoc 8 (entget xEnt)))) ; Layer
(assoc 50 (entget xEnt)) ; Rotation angle
(assoc 41 (entget xEnt)) ; Width factor
(assoc 71 (entget xEnt)) ; Text generation flags
(assoc 72 (entget xEnt)) ; Horizontal text alignment
(assoc 73 (entget xEnt)) ; Vertical text alignment
(assoc 74 (entget xEnt)) ; Text line spacing style
(assoc 210 (entget xEnt)))) ; Normal vector
(princ (strcat "\nNew text created with value of y: " newText))
(princ "\nError: Invalid insertion point.")
(princ "\nError: Invalid text height or style.")
(princ "\nError: Unable to calculate y. Please ensure all inputs are valid.")
(princ)
