Inserting calculation result as text
allwinaugustine
allwinaugustine
I was trying to create a lisp program to get the results using numbers from the text.
formulae is y=x-kd where,
x & d are extracted from the two different texts and value of k is as user input. I was able to get the values correct on command line. But unable to insert it as a text entity. I am getting an error called,
error: bad DXF group: nil
code is given below. Can someone please help me with it ?
(defun c:calculateY (/ xText dText k x d y xEnt dEnt entdata insertionPoint textHeight textStyle)
;; Prompt the user to select the text entity containing the value of x
(setq xEnt (car (entsel "\nSelect text entity containing the value of x: ")))
;; If a valid entity is selected for x
(if (and xEnt (eq (cdr (assoc 0 (entget xEnt))) "TEXT"))
(progn
(setq xText (cdr (assoc 1 (entget xEnt))))
(setq x (atof xText))
(progn
(princ "\nInvalid selection for x. Please select a text entity.")
(exit)
;; Prompt the user to select the text entity containing the value of d
(setq dEnt (car (entsel "\nSelect text entity containing the value of d: ")))
;; If a valid entity is selected for d
(if (and dEnt (eq (cdr (assoc 0 (entget dEnt))) "TEXT"))
(progn
(setq dText (cdr (assoc 1 (entget dEnt))))
(setq d (atof dText))
(progn
(princ "\nInvalid selection for d. Please select a text entity.")
(exit)
;; Prompt the user for the value of k
(setq k (getreal "\nEnter the value of k: "))
;; Calculate the value of y if x, d, and k are valid
(if (and x d k)
(progn
(setq y (- x (* k d)))
(princ (strcat "\nThe value of y is: " (rtos y 2 2)))
;; Get text height and style from x text entity
(setq textHeight (cdr (assoc 40 (entget xEnt))))
(setq textStyle (cdr (assoc 7 (entget xEnt))))
;; Ensure textHeight and textStyle are valid
(if (and textHeight textStyle)
(progn
;; Prompt for the insertion point of the new text
(setq insertionPoint (getpoint "\nSpecify insertion point for new text: "))
;; Ensure insertionPoint is valid
(if insertionPoint
(progn
(setq newText (rtos y 2 2))
(entmake (list (cons 0 "TEXT")
(cons 10 insertionPoint)
(cons 1 newText)
(cons 40 textHeight)
(cons 7 textStyle)
(cons 8 (cdr (assoc 8 (entget xEnt)))) ; Layer
(assoc 50 (entget xEnt)) ; Rotation angle
(assoc 41 (entget xEnt)) ; Width factor
(assoc 71 (entget xEnt)) ; Text generation flags
(assoc 72 (entget xEnt)) ; Horizontal text alignment
(assoc 73 (entget xEnt)) ; Vertical text alignment
(assoc 74 (entget xEnt)) ; Text line spacing style
(assoc 210 (entget xEnt)))) ; Normal vector
(princ (strcat "\nNew text created with value of y: " newText))
(princ "\nError: Invalid insertion point.")
(princ "\nError: Invalid text height or style.")
(princ "\nError: Unable to calculate y. Please ensure all inputs are valid.")
(princ)
komondormrex
you need to comment out line
because 'text' entity has no 74 group
allwinaugustine
Thank you so much Bro! You saved my day !
komondormrex
your welcome)
