A way to Lock an Entitiy
kpennell
Message 1 of 26
kpennell
Can anyone think of a way to lock an entity, that does not involve putting the entity on a locked layer? I'm wondering what people will come up with.
I think it would be a great feature request for Autodesk.
Replies (25)
Message 2 of 26
Kent1Cooper
Define it into a Block, and put the Block on a locked Layer?  You can lock multiple entities collectively that way if you want.  The entities will retain the characteristics of their native Layers, not of the locked Layer that the Block is on.
Kent Cooper, AIA
Message 3 of 26
john.uhden
Check out cadlock.com
It is run by gurus emeriti from earlier times around here.
John F. Uhden
Message 4 of 26
dbroad
Cadlock closed in 2015.  I don't see any benefit to entity locking BTW.
Architect, Registered NC, VA, SC, & GA.
Message 5 of 26
kpennell
I have some code that 'looks' for things.  And when those 'things' are not in the drawing, or changed location, deleted, exploded, it ends up being a longer winded way to complete the drawing.
If I had a magical piece of code, to unlock the entity, make my change and then lock it again, I could avoid such headaches.
We have a culture to try to teach the right and wrongs, but someone will always try to get to the finish line their way, which screws it up for the next guy.
I did notice the Vault is no longer.  But I play with it, and not quite what I was looking for.  My guts tells me KC's suggestion to be better, but I haven't tested it out yet from a code perspective.
Message 6 of 26
john.uhden
Isn't Owen still running Manusoft?
John F. Uhden
Message 7 of 26
dbroad
 "I have some code that 'looks' for things.  And when those 'things' are not in the drawing, or changed location, deleted, exploded, it ends up being a longer winded way to complete the drawing."
Sorry Kenny.  I can't really offer a helpful reply to such a vague description of "things".
@john.uhden  I have no idea and don't want to speculate.  If you search for Cadlock, the message is clear though.
Message 8 of 26
Ranjit_Singh
I would recommend 'looking' for entities using entity handles (not based on their xyz location). That way even if they move it makes no difference to your searching function. Also, if you want to lock them, locked layer is the most simplest and easiest option. You can make a block as recommended. Or get even fancier and attach reactors to your entities so they can't, be moved , edited, deleted etc.
Message 9 of 26
kpennell
I would love to get into reactors.  But I have no code to reference.
Yes, and I do look for entities not just based on x,y, and z coordinates.  The common one for me are attributes.  People explode them and therefore creating havoc.
Thanks all
Message 10 of 26
pareson
look here, maybe this will answer your question.
https://forums.autodesk.com/t5/autocad-forum/locking-objects/td-p/5917625.
i'd tried this sometime ago and it works.
Message 11 of 26
dbroad
The first step to protect blocks is to make them unexplodeable.
The second step is to pass out pick slips to the idiots who are still exploding them.
After that, I would consider fancier options.
Message 12 of 26
dgorsman
Define "lock an entity", and what purpose it would serve?
Message 13 of 26
ActivistInvestor
If by "lock", you mean to make an entity completely 'read-only' where it can't be modified using any means, there is a way to do that with ObjectARX (native or managed), but unfortunately not with LISP.
Message 14 of 26
john.uhden
Are we inviting Tony T. into this fray?  (arx)
John F. Uhden
Message 15 of 26
kpennell
Sorry, but got an 'invalid parameters' message from the link. But it's got me curious though.
Message 16 of 26
SeeMSixty7
Just remove the period off the end of the link.
Message 17 of 26
kpennell
This is the most in-line with what I'm going for. I know I can work with this. I just tested, including the 'Loading', 'ObjectLockCallBack' and the 'ObjectLockGetItem' silently, will keep the entity locked by anyone who opens the file.
Thanks so much for this.  I'm digging into the code the afternoon to figure out how this actually works.
Message 18 of 26
ActivistInvestor
Well, It actually doesn't work.
There's no commands started/ended when you edit objects using the Properties Palette, most controls on the Ribbon, and various controls on toolbars. Try editing a 'locked' object using one of those means. It doesn't work, because the whole thing is dependent on objects only being modified within commands.
Try using the BREAK or TRIM commands to break or trim a circle that's 'locked' (producing an arc).
Try using the TRIM command on a polyline, trimming it in multiple places. The code will undelete the original polyline, but it also leaves all of the new fragments created by TRIM intact.
Message 19 of 26
kpennell
I just noticed though, that this won't 'lock' attributes.
Message 20 of 26
ActivistInvestor
Something else you may not have noticed, which I would call a deal-breaker:
Load that code and lock one or more objects (one will do).
Next, draw a circle (or anything at all).
Next, issue the U command to undo the creation of the circle.
Then, issue the REDO command to redo the undo.
What do you see on the command line?
