Hello community, I would like to know if there is a possibility to change default "body style" - side view when generating profile in VHT ?
Knowledge says - choose from predefined library - but where is the library, how can I add my own blocks?
Here is the dialog where you choose the block ...
Solved by lendvot. Go to Solution.
These are predefined hard-coded styles and cannot be modified. However for presentation purposes you can create 3D block - see 1:00:10 approx
