Working with Files, FileDialogs.cls and BrowseFolder.bas
Ed__Jobe
Mentor Mentor
Message 1 of 1
Ed__Jobe
I'm posting this to bring together information I've gathered for working with files and folders in VBA. Attached are two zip files containing modules that you can import into your project. After downloading them, unzip them to reveal a  *.bas file. Then right click on your VBA project and select "Import File...". This will bring it in as a Class Module.
Below are some sample functions on how to use them. The samples use Windows dialogs to get strings representing files and folders.
Option Explicit
Public Sub OpenFile()
    'sample to show how to use FileDialogs
    Dim objFile As FileDialogs
    Dim strFilter As String
    Dim strFileName As String
    Set objFile = New FileDialogs
    'desc,filter combinations must all be separated with pipe char "|"
    strFilter = "Drawings (*.dwg)|*.dwg|All Files (*.*)|*.*"
    objFile.Title = "Open a drawing"
    'default dir is CurDir
    objFile.StartInDir = "c:\"
    objFile.filter = strFilter
    'return a valid filename
    strFileName = objFile.ShowOpen
    If Not strFileName = vbNullString Then
        'use this space to perform operation
        'MsgBox strFileName
        AcadApplication.Documents.Open strFileName
    Set objFile = Nothing
End Sub
Public Sub SaveFile()
    objFile.Title = "Save a drawing"
    'objFile.StartInDir = "c:\"
    strFileName = objFile.ShowSave
        'MsgBox strFileName
        ThisDrawing.SaveAs strFileName
End Sub
Public Function GetFolderPath(strDialogTitle As String, Optional strStartIn As String) As String
   Dim sPath As String
   If strStartIn = "" Then strStartIn = CurDir
   sPath = BrowseFolder.FolderBrowse(strDialogTitle, strStartIn)
   If sPath <> "" Then
      If BrowseFolder.FolderExists(sPath) Then
         GetFolderPath = sPath
End Function
To work with the files as objects, you can use the Windows FileSystemObject. To do this, you need to reference "Microsoft Scripting Runtime". For more information on scripting, see Microsoft's website. With FileSystemOjbect, you can do the types of things you would do in Windows Explorer, like move, copy, delete and rename. You can also open a stream for writing to a file.
Below is a sample of using the object.
Public Sub RenameDwg()
    Dim fso As Scripting.FileSystemObject
    Dim fsoFile As Scripting.File
    strFileName = "C:\Temp\SomeFile.dwg"
    Set fso = CreateObject("Scripting.FileSystemObject")
    If fso.FileExists(strFileName) = True Then
        Set fsoFile = fso.GetFile(strFileName)
        fsoFile.Name = "NewDwgName.dwg"
End Sub
Public Sub ListFolderContents()
    Dim fsoFldr As Scripting.Folder
    Dim strFolder As String
    strFolder = GetFolderPath
    If fso.FolderExists(strFolder) = True Then
        Set fsoFldr = fso.GetFolder(strFolder)
        For Each fsoFile In fsoFldr.Files
            Debug.Print fsoFile.Name
        Next
End Sub
Ed
How to post your code.
Replies (0)
