VP transparency
VP transparency
jeremye86
VP transparency
jeremye86
Is it possible to change the VP transparency of a layer?  LISP, vba or whatever code?
stefanveurink68AXD
Don't think this is possible in vba, but in .net api it must be possible.
reason i say this is with .net api is also possible to change vplineweight, vpcolor, so surely vptransparency must be there too.
only possible way i see in vba is by maybe using a dictionary. but dont know anything about this.
Norman_Yuan
As @stefanveurink68AXD pointed out, with AutoCAD .NET API, you can write code to do it via LayerViewportProperties class.
While there is no direct API support with AutoCAD COM API/VBA, if you really have to do it in VBA, you have to dig into undocumented ExtensionDictionary of AcadLayer object. Something like:
1. Test if an AcadLayer has ExtensionDictionary or not;
2. If it has, test if the dictionary has key "ADSK_XREC_LAYER_ALPHA_OVR" (the other 2 keys for layer's viewport overrides are "ADSK_XREC_LAYER_LINETYPE_OVR" and "ADSK_XREC_LAYER_LINEWT_OVR");
3. If the key exists, get the value of the dictionary item (Xrecord) form that key;
4. Parse the Xrecord to find the Alpha value (0-255) of the transparency applied to specific viewport;
5. Change the Alpha value in the Xrecord as needed
Again, since it is not exposed via API/not documented, it is up to you to investigate how the data are stored in ExtensionDictionary and parse/change it correctly.
Norman Yuan
Drive CAD With Code
