is it add notch possible on both sides of the bend line with rule
 blue line belong the  bend layer.
I want  notch (trangle vs.) both of side  the  line and delete  tihis line.
there are many blue lines for each piece
grobnik
Hi @Anonymous ,
how do you do ?
I guess that it's not impossible, if white line it's a polyline you can made a procedure that select white line, and blue line, calculate the intersection point of both, made the notch as adding vertex to white line, and delete the reference blue line.
It's not so easy but not impossibile, where to find notch dimension ? it are fixed ? require an operator input ?.
I can try if you share partial dwg or dxf
Bye
@grobnik  hi.
notch  dimension is  stabel. 1mm triangel for example
Sea-Haven
I normally do lisp so if you pick white pline then blue line you can work out 2 break points, as you have picked the pline once you break use entlast I know lisp then you will have the two entity names available, draw the wedge then use Join to make back into 1 pline do entlast again do other side.
