VBA code to save the file with another name
Message 1 of 12
Dear Folks...
I have a task to save the template drawing with 15 different (for 15 each typical level of a tower).
I am looking to have a code for that.
Initial try was to start with excel.. but got struck there.
Any help in this will be highly appreciated.
 Many Thanks in advance.
Replies (11)
Message 2 of 12
norman.yuan
This is AutoCAD VBA forum, I am not sure why you need to start with Excel to save AutoCAD drawing (as different drawing file name).
You use AcadDocument.SaveAs() to save current drawing to a given file name. Say, you have a template opened in AutoCAD, and want to save it as "MyDwg01.dwg", "MyDwg02.dwg"... "MyDwg15.dwg", you can:
Dim folder As String
Dim i as Integer
Dim fName As String
folder="C:\MyWork"
For i = 1 To 15
    fName="MyDwg" & Iif(i<10,"0" & i, i) & ".dwg"
    ThisDrawing.SaveAs folder & "\" & fName
Next
Note, after the For...loop, in the folder "C:\MyWork", you will see 15 drawing file saved, but in AutoCAD, only one drawing is open ("MyDwg15.dwg").
Norman Yuan
Drive CAD With Code
Message 3 of 12
Dear Yuan,
Thanks for the immediate response. The reasons starting with excel is, I don't any knowledge of VBA coding in ACAD, its setup and syntax. Another reason is I have a list of drawing names in a column in excel.
I appreciate your approach stating that this is Autodesk Forum, I would like to ask, is there any way we can open excel from ACAD application and read the names in cell say B1:B10 and start saving the CAD Template with these names.
Message 4 of 12
Sir,
I tried writing the below code in VBA of AutoCAD and then i save the files as "Save As 01.dvb"
It worked like a charm.
[Code]
Sub Save()
Dim i As Integer
Dim fName As String
folder = "C:\MyWork"
For i = 1 To 15
fName = "MyDwg" & IIf(i < 10, "0" & i, i) & ".dwg"
Next
End Sub
[/Code]
Can you please guide me through accessing the list from excel and saving these files with those names.
Message 5 of 12
norman.yuan
There are a lot sample code you can find if you google the net for Excel automation. Here is some quick code off my head without actual test:
Public Sub SaveNewDrawings()
    Dim fileNames as Variant
    Dim i As Integer
    folder="C:\MyDrawings\"
    fileNames = GetFileNamesFromExcelSheet("C:\MyDrawings\MyFileList.xlsx")
    If Ubound(fileNames)<0 Then Exit Sub
    For i=0 to Ubound(fileNames)
        ThisDrawing.SaveAs folder & fileNames(i)
    Next
End Sub
Private Function GetFileNamesFromExcelSheet(sheehFile As String) As Variant
    Dim fNames() As String
    Dim fName As String
    Dim i As Integer
    Dim xlsApp As Excel.Application
    Dim sheet As Worksheet
    Dim excelStarted As Boolean
    On Error Resume Next
    Set xlsApp=GetObject( , "Excel.Application")
    If Err.Number<>0 Then
        Err.Clear
        Set xlsApp=CreateObject("Excel.Application")
        excelStarted = True
    Enhd If
    On Error Goto 0
    If xlsApp Is Nothing Then
        MsgBox "Cannot open Excel application!"
    Else
        xlsApp.Workbooks.Open sheetFile
        '' Assume the active sheet is the sheet containing the data (A1 to A15)
        '' otherwise you need to identify which sheet to read the data
        For i=0 to 14
            fName=CStr(ActiveSheet.Range("A" & i+1).Value)
            ReDim Preserve fNames(i)
            fNames(i)=fName
        Next
    If excelStarted then xlsApp.Quit
    GetFileNamesFromExcelSheet=fNames
End Function
Again, the code is not tested. Just give you an idea.
HTH
Norman Yuan
Drive CAD With Code
Message 6 of 12
@norman.yuan
Hi, I just found this post and it's exactly what I've been trying to do. I've got a AutoCAD template and would like to save any number of copies based on a list of names in Excel. When I ran the untested code, I got the below error. My excel has no headers and the names are in A1:A5. I appreciate any help you can provide.
Message 7 of 12
norman.yuan
Luckily, I did claim my code was "off my head without actual test"Smiley Happy
Since the code runs in AutoCAD side, it will not automatically know what "ActiveSheet" is. So for the line of code that raises the error, change it to:
fName=CStr(xlaApp.ActiveSheet.Range("A" & i+1).Value)
HTH
Norman Yuan
Drive CAD With Code
Message 8 of 12
I updated the code and it resolved the error I was having, but created a new error. Thanks for any help you can provide.
Message 9 of 12
Ed__Jobe
You misspelled xlsApp as xlaApp.
Ed
How to post your code.
Message 10 of 12
I can't believe I missed that. It works now. Thanks!
Message 11 of 12
Ed__Jobe
If you use Option Explicit at the beginning of your module's declaration section, vba will alert you when you type a variable name without first explicitly declaring it.
Ed
Message 12 of 12
Dear Yuan,
thanks for your codes and guidance. It has really helped a lot and saved a lot of time.
Really appreciated.
Thanks a ton
Cheers !!!
    Dim i As Integer
    Next
End Sub
    Dim fName As String
    Dim i As Integer
        Err.Clear
        excelStarted = True
    Enhd If
    On Error Goto 0
    Else
        For i=0 to 14
            fNames(i)=fName
        Next
End Function
HTH
    Dim i As Integer
    Next
End Sub
    Dim fName As String
    Dim i As Integer
        Err.Clear
        excelStarted = True
    Enhd If
    On Error Goto 0
    Else
        For i=0 to 14
            fNames(i)=fName
        Next
End Function
HTH
