Selecting several blocks via filter
I am new in VBA and I have a question about an example I found on the internet for selecting blocks on AutoCAD.
This is the example (a filter):
Sub selectABlock()
   Dim sset As AcadSelectionSet
   Set sset = ThisDrawing.SelectionSets.Add("TestSet2")
   Dim filterType As Variant
   Dim filterData As Variant
   Dim p1(0 To 2) As Double
   Dim p2(0 To 2) As Double
   Dim grpCode(0) As Integer
   grpCode(0) = 2
   filterType = grpCode
   Dim grpValue(0) As Variant
   grpValue(0) = "testBlock"
   filterData = grpValue
   sset.Select acSelectionSetAll, p1, p2, filterType, filterData
   Debug.Print "Entities: " & str(sset.count)
   sset.Delete
End Sub
What do I do if I wish to filter more that one type of block to the selection?
I have tried something like:
grpValue(0) = "testBlock1" & "testBlock2" & "testBlock3"
but to no avail.
Please be thorough with your response, such as which lines you would modify, as I am a newbie.
Any help would be deeply apreciated,
kind regards
Ed__Jobe
Here is my solution for one block. You can call it in a loop or modify it to suit your needs. As is, you would call it like this:
Dim mySS As AcadSelectionSet
mySS = GetSS_BlockName("myblock")
Public Function GetSS_BlockName(BlockName As String) As AcadSelectionSet
    'creates a ss of blocks with the name supplied in the argument
    Dim s2 As AcadSelectionSet
    Set s2 = AddSelectionSet("ssBlocks")                ' create ss with a name
    s2.Clear                                        ' clear the set
    Dim intFtyp(3) As Integer                       ' setup for the filter
    Dim varFval(3) As Variant
    Dim varFilter1, varFilter2 As Variant
    intFtyp(0) = -4: varFval(0) = "<AND"
    intFtyp(1) = 0: varFval(1) = "INSERT"           ' get only blocks
    intFtyp(2) = 2: varFval(2) = BlockName          ' whose name is specified in argument
    intFtyp(3) = -4: varFval(3) = "AND>"
    varFilter1 = intFtyp: varFilter2 = varFval
    s2.Select acSelectionSetAll, , , varFilter1, varFilter2        ' do it
    Set GetSS_BlockName = s2
End Function
Another option would be to use the following function:
Public Sub BuildFilter(typeArray As Variant, dataArray As Variant, ParamArray gCodes())
'Purpose
'Fills a pair of variants with arrays for use as a selection set filter
'Arguments
'Two variants (not variant arrays) and an unlimited number of group code / value pairs
'Example
'BuildFilter fType, fData, 0, "LINE", 7, "WALLS"
    Dim fType() As Integer, fData()
    Dim index As Long, i As Long
    index = LBound(gCodes) - 1
    For i = LBound(gCodes) To UBound(gCodes) Step 2
        index = index + 1
        ReDim Preserve fType(0 To index)
        ReDim Preserve fData(0 To index)
        fType(index) = CInt(gCodes(i))
        fData(index) = gCodes(i + 1)
    Next
    typeArray = fType: dataArray = fData
End Sub
Public Function AddSelectionSet(SetName As String) As AcadSelectionSet
' This routine does the error trapping neccessary for when you want to create a
' selectin set. It takes the proposed name and either adds it to the selectionsets
' collection or sets it.
On Error Resume Next
Set AddSelectionSet = ThisDrawing.SelectionSets.Add(SetName)
If Err.Number <> 0 Then
Set AddSelectionSet = ThisDrawing.SelectionSets.Item(SetName)
AddSelectionSet.Clear
End Function
When building a filter, you can't simply concatenate strings. In your example, it would be searching for a single block named "testBlock1textBlock2testBlock3". You have to logically group multiple conditions using AND or OR.
You can call the above function like this:
Dim SS As AcadSelectionSet
Dim aryType As Variant
Dim arydata As Variant
Set SS = AddSelectionSet("findBlocks") BuildFilter aryType, arydata, -4, "<AND", 0, "INSERT", -4, "<OR", 2, "testBlock1", 2, "testBlock2", 2, "testBlock3", -4, "OR>", -4, "AND>" SS.Clear SS.Select acSelectionSetAll, , , aryType, arydata
Ed
How to post your code.
maratovich
Simpler. Need to use:
grpValue(0) = "testBlock1,testBlock2,testBlock3"
But all this does not make sense. It will not work.
Because the blocks in the drawing have the name "* U....."
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Worked perfectly (with the right names of my drawing, of course).
Thank you all 😄
Ed__Jobe
Oops, I missed that.
@Anonymous One problem with using the sub you showed is that it requires hardcoding the names into the routine. For example, you won't be able to prompt the user for the name. You can still use my sub, just use the string @maratovich supplied. Like this:
SS = GetSS_BlockName("testBlock1,testBlock2,testBlock3")
Ed
