Dinamic block get angle between starpoint and endpoint line
Message 1 of 1
I have block dinamic propertis (angle and distance1)
I want to get angle from line (starpoint and endpoint)
For exampe i have starpoint of line
1,10,0 'xyz
Endpoint of line 10,20,0
I want angle of my dinamic block follow line angle ( or same as with angle line)
I has try code but angle not match with line
Dim oBlk As IAcadBlockReference2
Dim oProps As Variant
Dim oDblkProp As AcadDynamicBlockReferenceProperty
Dim vPick As Variant
Dim I As Integer
Dim ft(0) as integer,fd(0) as variant
ft(0)=0:fd(0)="line"
Dim ss as acadSelectionSet
set ss = thisDrawing.selectionSet.add(now)
ss.selectOnScreen ft,fd
Dim L acadline
Set L = ss.item(0)
x = L.starPoint
y =L.endPoint
Myangle = atn(y(1)-x(1)/y(0)-x(0))
Set oBlk = ThisDrawing.ModelSpace.InsertBlock(x, "Test", 1#, 1#, 1#, 0#)
If oBlk.IsDynamicBlock Then
    oProps = oBlk.GetDynamicBlockProperties
    For I = 0 To UBound(oProps)
        Set oDblkProp = oProps(I)
        If oDblkProp.PropertyName = "Angle" Then
            oDblkProp.Value =myangle
            Exit For
    Next
Replies (0)
