Selecting objects on the model from selectionset created in VBA
jadeid91
jadeid91
I created a selection set which selects all objects in a certain layer. I looped over the selected objects successfully and highlighted them. Highlight property only highlights the objects. However, I cannot see any object selected on the scene... The dropdown list in the properties panel shows "No selection".
How do I select objects on the model from selectionset created in VBA?
Autocad Version: 2015
Code:
Function selectLayer(inLayer As String)
Dim polylines As AcadSelectionSet
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
Dim pl As AcadLWPolyline
On Error Resume Next
Set polylines = ThisDrawing.SelectionSets.Add("polylinesSS")
If Err.Number <> 0 Then
ThisDrawing.SelectionSets.Item("polylinesSS").Delete
FilterType(0) = 8
FilterData(0) = inLayer
polylines.Select acSelectionSetAll, , , FilterType, FilterData
'For Each entity In polylines
' If TypeOf entity Is AcadLWPolyline Then
' Set pl = entity
' pl.Highlight (True)
' End If
'Next
End Function
Ed__Jobe
When your code execution ends, the entities do not remain selected. There is a special selectionset called the PickfirstSelectionset. You access it via ThisDrawing.PickfirstSelectionset. When you click on an entity with your mouse, it is added to the pfss. Unfortunately, it is read-only. The vba methods are not intended to add anything to the pfss, it is read-only. The vba api is written so that you can manipulate the ss with code.
Ed
How to post your code.
norman.yuan
As you code shown (without commenting out the highlight portion), the code has already done the selecting correctly. You need to know that selecting programmatically (by code) and selecting manually are different thing.
In general, selecting by code, it is expected the selected entities would be subject to further code processing. Thus, it is up to the programmer to decide what to do with the entities selected by code. If you want user know visually that some entities are selected, you can highlight them, just as your code does.
However, if you want to leave some entities visibly selected (just as user manually select them) when your code is done, then you can do this:
Public Sub Test()
    Dim ss As AcadSelectionSet
    Set ss = ThisDrawing.SelectionSets.Add("TestSS")
    ss.Select acSelectionSetAll
    ss.Delete
    ThisDrawing.SendCommand "Select p " & vbCrLf
End Sub
As you can see, the code is to simply create a SelectionSet, do selection, and then delete the selection set. It purpose is to have AutoCAD cache a "Previous" selection, so the command "SELECT" with "P" option can select it. the result of command "SELECT" will also update Properties window.
HTH.
Norman Yuan
Drive CAD With Code
