How to import a iges file using vba?
Message 1 of 12
Hi, I'm new in this forum and I just trying to find the way to make a program to import iges file in Autocad 2017. The next program is what I have until now, this program look in to all folders seeking for any iges file, but I'm no able to import the file in to Autocad. If anyone could help me I'll appreciate it. Thanks
Sub DoFolder(Folder)
       Dim SubFolder
       Dim Cadena
       Dim Coordenate(0 To 2) As Double
       Dim myScale As Double
       Dim sFileName As String
       For Each SubFolder In Folder.SubFolders
              DoFolder SubFolder
       Next
       Dim File
       For Each File In Folder.Files
              sFileName = Right(File, 3)
              If sFileName = "dwg" Then
                     Do Until sFileName = ""
                     'Create a Document
                            Dim docObj As AcadDocument
                            Set docObj = ThisDrawing.Application.Documents.Add
                     'Open File
                            Coordenate(0) = 0#: Coordenate(1) = 0#: Coordenate(2) = 0#
                            myScale = 1#
                            ThisDrawing.Import File, Coordenate, myScale
                     'Save the document
                            File = Left(File, Len(File) - 3)
                            ThisDrawing.SaveAs File & "dwg"
                            sFileName = ""
                     Loop
       Next
End Sub
Replies (11)
Message 2 of 12
Ed__Jobe
I'm afraid the vba api doesn't have any method to import iges. The db Import method doesn't support as many file types as the IMPORT command. All you could do is call ThisDrawing.Sendcommand(). However, the IMPORT command and IGESIMPORT command are dialog-only commands. So you can't supply any commandline arguments to a call from SendCommand(). So you're kind of stuck. I don't think .NET is going to help either. I can't find any class methods that deal with iges. You can ask in the .NET forum though. Perhaps somebody else knows of a way.
Ed
How to post your code.
Message 3 of 12
Ed__Jobe
If you do want to use SendCommand, I found that the IMPORT command responds to setting FILEDIA to 0, whereas the IGESIMPORT command does not. However, if you use the IMPORT command, it responds appropriately to the correct file extension.
Ed
Message 4 of 12
You're right and thanks for your reply, I tried with sending commands from vb and setting filedia = 0, but when the file is imported autocad just show to popup windows displaying that my file is ready, after that I need to click with the mouse to be able to use the import file on the drawing. I already tried many methods to disable this popup windows but nothing works for me. If I find the method to disable this popup windows and make that the file is directly inserted on the drawing the problem will be solved. Do you have any idea how to do it?
This is the code I'm using for
ThisDrawing.SendCommand "Import" & vbCr & "C:\Users\JEF User\Desktop\Test\2S-BR-2036.igs" & vbCr
and then the popup windows appears waiting for a mouse click  -_-
Message 5 of 12
Ed__Jobe
Click on the checkbox "Don't show this message again". The notification balloons that popup don't interfere with execution.
Ed
Message 6 of 12
There's not option for that :\, (see attachments)
Message 7 of 12
Ed__Jobe
I don't see any way around that.
Ed
Message 8 of 12
The problem is that I can not automate this process because the imported file never opens because I need to click the little window on the corner. I need to figure out the way to make the imported file be opened automatically to be able to save it from VBA
Message 9 of 12
Ed__Jobe
Unfortunately, I don't think you will accomplish it via scripting the command line. The only other info I could find is in this post.
Ed
Message 10 of 12
This is the answer for my question:
      Dim File as String
      File = Path of the File
      'Create Drawing
      'Open
            ThisDrawing.SendCommand "_Import" & vbCr & File & vbCr
            Sleep 1000 'Because my computer I have a slow computer
            ThisDrawing.SendCommand "IMPORTTRANSLATIONRESULT" & vbCr
            ThisDrawing.SendCommand "REGEN" & vbCr
      'Save
            ThisDrawing.SaveAs Left(File, Len(File) - 4)
      'Close
            ThisDrawing.Close
Message 11 of 12
Hey @Anonymous . Thanks for posting this. The sleep function you kept calling wouldn't work. Not sure what I was doing wrong or what you referenced to use the internal timer.
However, found a version similar to your import approach with a custom Sleep workaround here: VBA Convert 3D .STEP to older .DWG for AutoCAD  by @Anonymous
Figure I'd share since I can't stand AutoCAD's dreaded Notificaiton Bubbles during automation routines that leverage the command line. They cause so many snags, and the potential of a decent program creation.
Message 12 of 12
JOSE-MIGUEL_AUNION
Hi, the SLEEP function is not built in by default in the Visual Basic system. You have to import it via this declaration:
Public Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal milliseconds As LongPtr)
for Office 64 bits.
really handy.
