Opening Excel only once from AutoCAD 2014 VBA
Message 1 of 11
I am trying to open an excel from a Autocad 2014 VBA, this works fine, however, I do not want the file to re-open if it is already open. I did a lot of research and found the following code, which does not work. I included the excel file for reference, you will have to update the folder if you want to run it. Again, I can open the file but I want to skip re-opening it if it is already open. input please. I have already tried varients on the
Set Test_wb = objExcel.Workbooks(Name)
using File as well does not work. I also used the code from here: https://www.experts-exchange.com/questions/28950354/My-myFile-xlsm-2010-file-is-already-open-how-can.... it seems to work fine if in excel vba.
Sub Test_Open_Excel()
    Dim i As Integer
    Dim wb, Test_wb As Workbook
    Dim folder, File, Name As String
    Set objExcel = CreateObject("Excel.Application")
    folder = "C:\Users\T6145M1\Desktop\Files\Programing\VBA for AutoCAD\"
    Name = "Conceptual_Flow_Excel.xlsm"
    File = folder & Name
    On Error Resume Next
    On Error GoTo 0
    'If workbook is not opened, Test_wb will be nothing and you can attempt to open it
    If Test_wb Is Nothing Then
       Set wb = objExcel.Workbooks.Open(File, , False)
       objExcel.Application.Visible = True
    Else
       Set wb = objExcel.Workbooks(File)
    wb.Activate
End Sub
Replies (10)
Message 2 of 11
norman.yuan
The code should do things in this way:
1. Try to get an existing Excel application. If no Excel application is running, start a new Excel application session;
2. Loop through all the Workbooks in the Excel application, to see if the Excel file (Workbook) is open or not. If not, open.
Here is the sample code (off my head, not tested)
'' in the module/class, delare variables
Private excelApp As Excel.Application
Private wk As Excel.Workbook
Private Sub GetExcelObjects(fileName as String)
    Set excelApp=Nothing
    Set wk=Nothing
    '' Make sure Excel application is running
    Set excelApp=GetObject( , "Excel.Application")
    If excelApp Is Nothing Then
        Set excelApp=CreateObject("Excel.Application")
            MsgBox "Cannot start Excel Application!"
            Exit Sub
    End if
    '' Make sure the Workbook is open
    On Error GoTo 0
    Dim w As Excel.Workbook
    For Each w In excelApp.Workbooks
        If UCase(w.FullName)=UCase(fileName) Then
            Set wk=w
            Exit Sub
        End if
    Next
    If wk Is Nothing Then
        Set wk = excelApp.Workbooks.Open(fileName, , False)
        MsgBox "Cannot open file: " & vbCrlf & fileName
    Else
        wk.Activate
End Sub
HTH
Norman Yuan
Drive CAD With Code
Message 3 of 11
I had to make 1 change but this seems to work very well, I will continue to follow up and test it, thanks for your help.
Private Sub GetExcelObjects()
    Dim excelApp As Excel.Application
    Dim wb As Excel.Workbook
    Dim folder, Name, FileName As String
    Dim ExcelWasNotRunning As Boolean
    Set excelApp = Nothing
    Set wb = Nothing
    FileName = folder & Name
    Set excelApp = GetObject(, "Excel.Application")
    If Err.Number <> 0 Then ExcelWasNotRunning = True
    Err.Clear    ' Clear Err object in case error occurred.
    If ExcelWasNotRunning Then
        Set excelApp = CreateObject("Excel.Application")
        excelApp.Application.Visible = True
            Exit Sub
    On Error GoTo 0
        If UCase(w.FullName) = UCase(FileName) Then
            Set wb = w
            Exit Sub
    Next
    If wb Is Nothing Then
        Set wb = excelApp.Workbooks.Open(FileName, , False)
        MsgBox "Cannot open file: " & vbCrLf & FileName
    Else
        wb.Activate
End Sub
Message 4 of 11
norman.yuan
For this part of code:
            Exit Sub
you may want to change it to (otherwise, if excelApp is not created, the code would crash before showing the messagebox):
            Exit Sub
Else
excelApp.Application.Visible = True End If End If
Norman Yuan
Drive CAD With Code
Message 5 of 11
elaborating on @norman.yuan solution
1) you can demand the task of getting an Excel Application instance to a function:
Function GetExcel(excelApp As Excel.Application) As Boolean
    Set excelApp = GetObject(, "Excel.Application") '<--| try and get a running instance of Excel
    If excelApp Is Nothing Then Set excelApp = CreateObject("Excel.Application") '<--| try opening a new instance of Excel
    GetExcel = Not excelApp Is Nothing '<--| notify the success of the function task
End Function
  which returns either "True" if successful along with a valid Excel instance or "False" along with a null object
2) no need to iterate through workbooks collection to see if a workbook is there: you simply try getting that workbook
Function GetExcelWb(excelApp As Excel.Application, fileName As String, wb As Object) As Boolean
    Set wb = excelApp.Workbooks(fileName)  '<--| try and get an already opened workbook named after "Name"
    GetExcelWb = Not wb Is Nothing  '<--| notify the success of the function task
End Function
 which returns either "True" if successful along with a valid workbook instance or "False" along with a null object
3) in the same manner you can demand the task of opening a workbook to a function
Function OpenExcelWb(excelApp As Excel.Application, fullFileName As String) As Excel.Workbook
    Set OpenExcelWb = excelApp.Workbooks.Open(fullFileName)  '<--| try and get the requested workbook
End Function
which either returns the opened workbook or a null object
so that your main sub can be rewritten as follows:
    If GetExcel(excelApp) Then '<--| if successfully got a Excel instance..
        Dim folder As String, name As String, fullFileName As String '<--|explicitly define each declared variable, otherwise they'll be implicitly assumed as of Variant type
        name = "Conceptual_Flow_Excel.xlsm"
        fullFileName = folder & name
        If Not GetExcelWb(excelApp, name, wb) Then Set wb = OpenExcelWb(excelApp, fullFileName) '<--| if not succesfully found an already opened workbook with given name, then try and open it
            MsgBox "Cannot open file: " & vbCrLf & fullFileName, vbCritical
        Else
            wb.Activate
    Else
        MsgBox "Cannot start Excel Application!", vbCritical
End Sub
this way you keep all that "On Error Resume Next"  stuff confined where it's actually needed and your main code more understandable and clean
Message 6 of 11
I haven't been able to get this to work. It just doesn't open the file. Did it work for you?
Message 7 of 11
So I think part of the problem is that excelApp reads as "Microsoft Excel" even when excel isn't open, so it misses the
execution.
Message 8 of 11
I updated this function with the following:
End Function
now it seems to perform as desired, thanks everyone.
Message 9 of 11
You should take that added red line out of GetExcel function and put it into the “main” sub (i.e. GetExcelObjects()), as follows
excelApp.Visible = True
The reason is that inside GetExcel() function excelApp could still be “Nothing” while after successfully passing the “If GetExcel(excelApp) Then“ check it must be set to a valid object
Message 10 of 11
continentalcamapign
Community Visitor
Community Visitor
Message 11 of 11
Ed__Jobe
First, you should try GetObject function to see if there is an instance of excel already running. If not, it will error. If that happens, only then should you use CreateObject. Otherwise you’ll end up creating a bunch of application objects until you run out of resources.
Ed
How to post your code.
