VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Max() Function
2 REPLIES 2
2146 Views, 2 Replies
Max() Function
Is it possible to find the largest of a group of numbers in Acad VBA similar
to the Excel Max() function?
Best regards,
Dale
2 REPLIES 2
... nope -- hafta write'em -- (lisp has them -- funny why VBA doesn't):
Syntax for all four functions below:
Minimum(1,2,5,6,3,etc...)
Min(Array)
Maximum(1,2,5,6,3,etc...)
Max(Array)
'================================== watch for word wrap
Public Function Minimum(ParamArray Numbers())
Minimum = Min(Numbers)
End Function
Public Function Maximum(ParamArray Numbers())
Maximum = Max(Numbers)
End Function
'Send back the minimum value from a list of numbers
Public Function Min(ByVal NumericArray As Variant) As Variant
Dim i As Integer
Dim MinVal As Double
Dim CurVal As Double
CurVal = NumericArray(0)
MinVal = CurVal
For i = LBound(NumericArray) + 1 To UBound(NumericArray)
CurVal = NumericArray(i)
If CurVal < MinVal Then MinVal = CurVal
Next
Min = MinVal
End Function
'Send back the maximum value from a list of numbers
Public Function Max(ByVal NumericArray As Variant) As Variant
Dim i As Integer
Dim MaxVal As Double
MaxVal = CurVal
If CurVal > MaxVal Then MaxVal = CurVal
Next
Max = MaxVal
End Function
Dale and Lanny,
Is this what you are referring to?
Public oExcel As New Excel.Application
Public Sub DoesThisWork()
Debug.Print oExcel.WorksheetFunction.Max(12, 13, 2, 1, 0, 42)
End Sub
Don't forget to set your reference to Excel.
Get on the emailing list for notification of the NEW "AutoCAD Visual Basic
Programmers Reference" - the ultimate guide to Visual Basic programming for
R14/2000/2000i
and 2002 by clicking on the link below
mailto:omnisource@worldnet.att.net?subject=NewVBTitle
Joe Sutphin
Author of "AutoCAD 2000 VBA Programmers Reference"
ISBN #1861002564
"Lanny Schiele" wrote in message
news:682BA3B8C4D8F0956B7CF9F65DC6CEDA@in.WebX.maYIadrTaRb...
> Min(Array)
> Max(Array)
> End Function
> End Function
> Dim i As Integer
> MinVal = CurVal
> Next
> Min = MinVal
> End Function
> Dim i As Integer
> MaxVal = CurVal
> Next
> Max = MaxVal
> End Function
Forma Design Contest
AutoCAD Beta
