LABEL MULTIPLE POLYGONS WITH AREA LABEL
Message 1 of 9
I have a series of closed polygons and would like to label each with it's area from the object properties.
What is the best way to do this?
Can anyone help me please.
Regards
R
Replies (8)
Message 2 of 9
Use Field might be easiest way.
from the object properties. What is the best way to do this? Can anyone help
me please. Regards R
Message 3 of 9
HJohn1
Norman could you explain how to do that using fields? I don't use fields, but would like to see how to get the area of the polyline into the field. TIA
Message 4 of 9
1. Open a drawing in Acad
2, Enter "Field" at command line;
3. Highlight "Object" in Field names:"
listbox;
4. Click small button to pick a
polyline;
5. In "Property:" list box, select
"Area";
6. Choose appropriate format.
7. Click OK to insert Field text
somewhere.
8. Re-shape the polyline so that its area is
changed.
9. Regen the drawing, you'll see the field text
(area's value) changes accordingly.
You can also manipulate a field from VBA code. A
field is just a AcadMText or AcadText with IAcadMText2/IAcadText2 interface. See
AutoCad VBA help on IAcadMText2/IAcadText2 for how to use VBA code to create
Field.
Norman
TIA
Message 5 of 9
HJohn1
Norman, thank you very much for your help. I don't know why I never looked into fields before, but I will for now on. I could not find any information about the IAcadMText2 and IAcadText2 reference in the VBA documentation on the help folder of AutoCAD. I am using AutoCAD 2007. Could you let me know where to find this information, which document?
Message 6 of 9
Simply go to Acad VBA IDE and look into Object
Browser. There are quite some objects named like IAcadxxxx2[3], which were added
into Cad object model and used for adding new functionalities to existing Acad
objects when AutoCAD evolves with each new version.
Norman,
Message 7 of 9
HJohn1
Norman you need to excuse my ignorance but I can't find any reference to either one of these interfaces in the object model. I look into both AutoCAD 2007 and AutoCAD/ObjectDBX type libraries. The ObjectDBX library contains some IAcadxxx objects but not the IAcadMtext2 or IAcadText2. I found a fieldcode example where an IAcadText2 is used, but I can't run it. I get a "User-defined object not defined" error. Could you please tell me where you found these objects?
Message 8 of 9
OK, my main working computer still use Acad2006,
these IAcadxxxx stuff were introduced for added feature of Text and block, that
is, Field, Dynamic Block... in order to keep Acad's compatibility within the
same version of multiple releases (acad2004-2006, V16).
In V17 (Acad2007-2009), most of the IAcadxxxxstuff
were merged into AcadText.....
So, in Acad2005/6, the AcadText does not have
FieldCode() method, it only exists in IAcadText2. You have see it in VBA help
file.
However, in Acad2007/8, that sample code does not
run (Acad does a very poor help file update between release, they are so busy to
rush out yearly new release and hope people for get anything linked to older
versions.
Since Field is simply a AcadText/MText with
field code, you need to change the sample code
from
Dim textObject As IAcadText2
to
Dim textObject As AcadText
Then the code will run.
Norman
objects?
Message 9 of 9
HJohn1
Norman, thank you again. I finally noticed that both the AcadMtext and AcadText objects have fieldcode methods.
