centerpoints
centerpoints
X1JIANGWOO
Message 1 of 18
centerpoints
X1JIANGWOO
Hello guys,
I am trying to create a program the notifies the user if a circle on one layer shares a centerpoint with a circle on another layer.
Basically, we have a "stud" layer and an "etch" layer. The etch layer tells the laser to etch a reference circle so studs can be welded in the proper spot. What is happening is the etch circle is missing or off center when the drawing is completed. I am trying to find a way to run a program when finalizing the drawing so we know that all studs have the "etch" circles attached. Both circles are brought into the drawing when inserting blocks but when there is customization, things get moved or deleted.
Any advice is greatly appreciated.
Replies (17)
Message 2 of 18
easiest might be....
erase all etch circles
for each stud circle
    copy @
    change to etch
layer
Next stud circle
else you'd have to
    For each stud
circle
        For
each etch circle
size=2>            look
for match
        Next
etch
    Next stud
lots of excess processing there
hth
mark
Hello
guys, I am trying to create a program the notifies the user if a circle on one
layer shares a centerpoint with a circle on another layer. Basically, we have
get moved or deleted. Any advice is greatly
appreciated.
Message 3 of 18
X1JIANGWOO
How would I go about starting this? I'm new to VBA. Edited by: X1JIANGWOO on Nov 19, 2008 5:41 PM
Message 4 of 18
So, each pair of stud/etch circles are in a block? How is it *one* of these gets moved without the other?
Message 5 of 18
Are the circles all in model space?
are the layer names exactly what you
wrote?
How
19, 2008 5:41 PM
Message 6 of 18
X1JIANGWOO
When the block is exploded because some sort of customizing is required, there usually is a lot of stretching and moving.
Message 7 of 18
If the etch circles are to be the same size as the
stud circles this might work
Sub StudEtchCircles()
  Dim oEnt As
AcadEntity
  Dim oCirc As AcadCircle
  'DELETE ETCH
CIRCLES
  For Each oEnt In ThisDrawing.ModelSpace
If TypeOf oEnt Is AcadCircle Then
      If
UCase(oEnt.Layer) = "ETCH" Then
oEnt.Delete
    End
If
  Next oEnt
  'COPY STUD CIRCLES TO
ETCHLAYER
  For Each oEnt In
Then
      If UCase(oEnt.Layer) = "STUD"
Then
        Set oCirc =
oEnt.Copy
        oCirc.Layer =
"ETCH"
    End
If
  Next oEnt
End Sub
  hth
mark
When
Message 8 of 18
When the blocks are modified or moved. We rarely use the etch layer so sometimes modifications are accidentally done with out the layer being on. Sometimes, the etch is forgotten when making a custom block,
Message 9 of 18
Mark, I think your idea is great. Unfortunately the stud circles have a different size than the etch circle. It doesn't matter what size the stud circle is but all etch circles are to be 1 size. Is there a way I could set all of the circles(now on the etch layer) all to 1 size?
Message 10 of 18
Yes,
read the help on acad circle
they have a radius and diameter
property
set that (whichever one you want to use) in the
code after creating the etch circle
hth
mark
Mark,
Message 11 of 18
Mark,
Thanks for all of the help. How would I modify the code so I delete every circle on the etch layer but the ones with a diameter of 3? Or just copy only the circles that do not have a diameter of 3? I've tried many different ways but I get errors. I'm not familiar with the typeof methods.
Xi
Message 12 of 18
if Not oCircle.Diameter = 3 then
    oCircle.Delete
be aware of rounding issues with that kind of thing
(floating point values in any computer system)
you can also apply a fuzz factor to get ones that
are virtually =3 but maybe show as 2.9999999999999 etc
eg
Function EqualFuzz(a As Double, b As Double, fuzz
As Double) As Boolean
  If Abs(a - b) < fuzz
Then
    EqualFuzz = True
  Else
EqualFuzz = False
End Function
hth
mark
Mark,
but I get errors. I'm not familiar with the typeof methods. Thanks,
Xi
Message 13 of 18
Thanks again Mark.
This is what I have for code:
{code}
Sub cetch()
Dim oEnt As AcadEntity
'DELETE ETCH CIRCLES
If UCase(oEnt.Layer) = "ETCH" Then
If Not oCirc.Diameter = 3 Then
oCirc.Delete
Next oEnt
{code}
I keep getting a "Object variable or With block variable not set" error. I'm sure this something I'm doing fundamentally wrong. The closer I look at it the further away from the answer I go.
Do I need to set the diamter?
Message 14 of 18
I forget if you are doing this in dbx or in the
editor?
if in editor you could also use filtered selection
for part of this
what line are you getting the error on, and can you
post so the lines don't all run together?
mark
again Mark. This is what I have for code: {code} Sub cetch() Dim oEnt As
AcadEntity Dim oCirc As AcadCircle 'DELETE ETCH CIRCLES For Each oEnt In
ThisDrawing.ModelSpace If TypeOf oEnt Is AcadCircle Then If UCase(oEnt.Layer)
= "ETCH" Then If Not oCirc.Diameter = 3 Then oCirc.Delete End If End If End If
Next oEnt {code} I keep getting a "Object variable or With block variable not
I look at it the further away from the answer I go. Do I need to set the
diamter?
Message 15 of 18
I am using the editor.
I get the error at "If Not oCirc.Diameter = 3 Then"
Sub cetch()
If UCase(oEnt.Layer)= "ETCH" Then
oCirc.Delete
Next oEnt
I get the error at line "If Not oCirc.Diameter = 3 Then"
Message 16 of 18
you never cast the oEnt to the oCirc
so either replace oCirc with oEnt or set oCirc =
oEnt when you find it is a circle
Sub cetch()
Dim oEnt As
AcadEntity
'DELETE ETCH
CIRCLES
If TypeOf oEnt
Is AcadCircle Then
 '<---------- here you can Set
oCirc = oEnt to get intellisense on the properties of a
circle
size=2>
'-------------- then instead of using oEnt use
oCirc ... it's not necessary but makes code more explicit
' all entity types derive from AcadEntity but
each type has its own additional properties specific to itself
' eg a line has .Startpoint, a circle has .Center
....etc etc
Then
oCirc.Delete
Next oEnt
oCirc.Diameter = 3
Then"
Message 17 of 18
Mark,
I knew it was something simple. Thanks for all of the help.
Xi
Message 18 of 18
You're welcome
glad it worked
mark
Mark,
Xi
