Change object-propertie by OD of object gives error
Message 1 of 1
This is a repost, now used the Rich Text, so it should be readable.
I want to change the layer of an object by looking in the ObjectData.
With this code I see the ObjectData, put the string in a variable,
close something (the debugger gives me back the object properties), but
the layer cannot be set (see last line) because: "Object was open for
read". Thats true, but changing the flag should do the trick I thought.
Can someone tell me whats wrong?
Peter
Dim sset As Object
Dim laag As String
Dim acadobj As Object
Dim oproj As Object
Dim odatatable As Variant
Dim orecords As Variant
Dim flag As Variant
Dim rec As Variant
Set oAcadApp = ThisDrawing.Application
Set oAcadMap = oAcadApp.GetInterfaceObject("AutocadMap.Application")
Set AcadDoc = oAcadApp.ActiveDocument
Set oproj = oAcadMap.Projects(ThisDrawing)
Set odatatable = oproj.ODTables.Item("default_top10_vlak") 'created table inside drawing
Set orecords = odatatable.GetODRecords
'Give selection.
Set sset = AcadDoc.ActiveSelectionSet
sset.Clear
sset.SelectOnScreen
'Loop Through Entities
For Each acadobj In sset
flag = orecords.init(acadobj, True, False)
If flag = True Then
If orecords.isdone = False Then
Set rec = orecords.Record
laag = rec.Item(1).Value
'If InStr(1, laag, "/") Then Mid(laag, InStr(1, laag, "/"), 1) = "_"
'If InStr(1, laag, "\") Then Mid(laag, InStr(1, laag, "\"), 1) = "_"
End If 'IsDone=FALSE
End If 'flag=TRUE
'check_laag (laag) 'checks if layer exist. If not, then create it
flag = orecords.init(acadobj, False, True) 'Give back the properties
acadobj.Layer = laag 'Why is here a run-time error (-2145386418 (8020004e)) ?
Next acadobj
Replies (0)
