GetDynamicBlockProperties Null object ID error for profile <<ACADMPP>>
jeremye86
Message 1 of 9
jeremye86
Im filling dynamic block attributes with GetDynamicBlockProperties but Im getting Null object ID error  for profile <<ACADMPP>> .  Everything works fine under the profile <<VANILLA>>.  Please help as some users like to use different profiles.
Replies (8)
Message 2 of 9
Ed__Jobe
Different profiles can load different libraries. Apparently something is missing from <<ACADMPP>> that <<VANILLA>> has. You don't provide much other info to troubleshoot with, like maybe the line that errors or what object is missing.
Ed
How to post your code.
Message 3 of 9
jeremye86
Sub test()
    Dim objBlockRef As AcadBlockReference
    Dim BlkAtts As Variant
    Dim PntPerimSht(0 To 2) As Double
    Dim i As Long
    Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(PntPerimSht, "perimShtDyn", 1, 1, 1, 0)
    BlkAtts = objBlockRef.GetDynamicBlockProperties
    On Error Resume Next
    For i = 0 To UBound(BlkAtts)
        Debug.Print BlkAtts(i).Value & "   " & i
    Next i
    On Error GoTo 0
    BlkAtts(0).Value = 293#   'i am getting error here for  <<ACADMPP>> profile
    BlkAtts(2).Value = 7#
    BlkAtts(4).Value = 7#
    BlkAtts(6).Value = 45#
    BlkAtts(8).Value = 16.2
    BlkAtts(14).Value = 7#
    BlkAtts = objBlockRef.GetAttributes
    BlkAtts(0).TextString = "CP" & 1 & "A"
End Sub
Message 4 of 9
jeremye86
i attached the code and the block im using above
Message 5 of 9
Ed__Jobe
I was unable to duplicate the error. When you are in the <<ACADMPP>> profile, go to Tools>References in the vbaide and see if there are any references that say MISSSING in front of them.
Ed
Message 6 of 9
jeremye86
i didn't see anything missing in the library.
when the shortcut target is this i get an error
"C:\Program Files\Autodesk\AutoCAD 2017\acad.exe"  /p <<ACADMPP>> /product ACADM /language "en-US"
when the shortcut target is this i dont get an error
"C:\Program Files\Autodesk\AutoCAD 2017\acad.exe" /p <<VANILLA>> /product ACADM /language "en-US"
Message 7 of 9
Ed__Jobe
Try modifying your code like below and step through the execution. See if you get a different error and what line is it on. Do you know how to set a breakpoint and step through code execution?
    'On Error Resume Next
    For i = 0 To UBound(BlkAtts) Step 2
    Next
    'On Error GoTo 0
Ed
Message 8 of 9
jeremye86
Ed thanks for your responses, i figured it out.
If i use
 ThisDrawing.Regen acActiveViewport
or
Application.Update
after this line Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(PntPerimSht, "perimShtDyn", 1, 1, 1, 0)
then the code works.
I sill confused though.  Do you know why i would need this for for certain profiles but not for others?
Message 9 of 9
Ed__Jobe
I'm not sure, as I don't know where the error is coming from yet.
Ed
