VBA - Return selection to user for further manipulation
I've tried hard to figure this out but to no avail. When you run an AutoCAD command that works on a selection (like `move`, `erase`, `mirror`, etc), it usually prompts you to make a selection. But if you have already selected some entities, it simply starts the `move`/`erase`/`mirror` operation.
I want to make a macro that would loop through every entity in `ModelSpace` and select some of them that fulfill a certain criteria (like maybe all lines that are horizontal or vertical). At this point I want the macro to end with the objects selected by the macro available for use by a regular AutoCAD command that the user can then run.
For instance:
1. The user runs the macro
2. Macro selects all lines having same X or Y coordinates and exits
3. The user then uses the PROPERTIES window to change some of their properties, or she could enter `E` to erase these lines, or `MI` to mirror them, etc.
Is this even possible? Cuz I have never come across a similar issue being brought up by ppl in the acad community,
Ed__Jobe
Below is a sample that selects text only from the current space. The only problem is that once the code finishes running, the selectionset will not be active. However, you can just use the Previous option when prompted to select entities in the MOVE command. I used the Highlight option just to show you its working.
Public Function AddSelectionSet(SetName As String) As AcadSelectionSet
' This routine does the error trapping neccessary for when you want to create a
' selectin set. It takes the proposed name and either adds it to the selectionsets
' collection or sets it.
    On Error Resume Next
    Set AddSelectionSet = ThisDrawing.SelectionSets.Add(SetName)
    If Err.Number <> 0 Then
        Set AddSelectionSet = ThisDrawing.SelectionSets.Item(SetName)
        AddSelectionSet.Clear
End Function
Public Function GetSS_TextFilter() As AcadSelectionSet
    'creates an ss of Text only
    Dim s1 As AcadSelectionSet      'for filtered ss
        'filter is needed if there's no pfss
        Dim intFtyp(0) As Integer                       ' setup for the filter
        Dim varFval(0) As Variant
        Dim varFilter1, varFilter2 As Variant
        intFtyp(0) = 0: varFval(0) = "TEXT"             ' get only text
        varFilter1 = intFtyp: varFilter2 = varFval
        Set s1 = AddSelectionSet("ssTextFilter")        ' create or get the set
        s1.Clear                                        ' clear the set
        s1.Select acSelectionSetAll, , , varFilter1, varFilter2      ' do it
    Set GetSS_TextFilter = s1
End Function
Sub test2()
    Dim ss As AcadSelectionSet
    Set ss = GetSS_TextmFilter()
    ss.Highlight True
End Sub
Ed
How to post your code.
norman.yuan
In addition to @Ed__Jobe's excellent code, I add a bit more so the code would do what you exactly want: use VBA code to simulate user's manual selecting:
Option Explicit
Private Const MY_SS As String = "MySelectionSet"
Public Sub DoSelection()
    '' Select all circles
    CreateSelection "CIRCLE"
    '' Or select all Lines
    ''CreateSelection "LINE"
    '' Or select everything
    ''CreateSelection ""
    '' Send the selectionset to AutoCAD editor
    '' so that they look like being selected by user and highlighted
    ThisDrawing.SendCommand "SELECT" & vbCr & "P" & vbCr & vbCr
End Sub
Private Sub CreateSelection(entType As String)
    Set ss = ThisDrawing.SelectionSets(MY_SS)
    If ss Is Nothing Then
        Set ss = ThisDrawing.SelectionSets.Add(MY_SS)
    Else
        ss.Clear
    Dim GType(0) As Integer
    GType(0) = 0
    Dim GVal(0) As Variant
    GVal(0) = entType
    If UCase(entType) = "CIRCLE" Or UCase(entType) = "LINE" Then
        ss.Select acSelectionSetAll, , , GType, GVal
    Else
    ''MsgBox "Selected entity count: " & ss.Count
End Sub
Once you run the VBA macro "DoSelection", either all circles (or all lines, or all entities) will be highlighed as if they are selected by user, and the properties window would update according the selection.
HTH
Norman Yuan
Drive CAD With Code
