For loop stops at step 200
erhan.lale
erhan.lale
I have really simple document. There is only 1116 circles on one layer.
I want to transfer radius of each circle and wrote really simple VBA code:
Sub radiusOfCircles()
    Dim ent As AcadEntity
    For Each ent In ThisDrawing.ModelSpace
      If TypeOf ent Is AcadCircle Then
        Debug.Print ent.Radius
    Next
End Sub
 I wanted do copy from debug window. If I run it, I get only 199 objects. I have no idea why.
fkellogg
Can you not simply do a Data Extraction?
Ed__Jobe
It's a limitation of the IDE. Acad also has this limitation. The command line (F2) history can only store 400 lines. Write the data to Excel instead.
    Dim xl As Excel.Application
    Dim wb As Excel.Workbook
    Dim sht As Excel.Worksheet
    Set xl = GetXL()
    Set wb = xl.Workbooks.Add
    Set sht = wb.Worksheets(1)
    sht.Name = "circles"
    Dim i As Integer
    sht.Cells(1, "A").Value = "Handle"
    sht.Cells(1, "B").Value = "Radius"
    i = 2
        sht.Cells(i, "A").Value = ent.Handle
        sht.Cells(i, "B").Value = ent.radius
      i = i + 1
    Next
    wb.SaveAs "C:\Temp\RadiusOfCircles.xlsx"
    Set sht = Nothing
    Set wb = Nothing
    Set xl = Nothing
End Sub
Public Function GetXL() As Application
    On Error Resume Next
    Dim xlApp As Application
    Set xlApp = GetObject(, "Excel.Application")
    If xlApp Is Nothing Then
        Set xlApp = CreateObject("Excel.Application")
    Set GetXL = xlApp
End Function
Ed
How to post your code.
fkellogg
@erhan.lale
Thanks for the Solution!
The extent of my knowledge of lisp code is the defun: C thing.
My acaddoc.lsp file is chock full of ways to bypass tedious keystrokes and dialog boxes.
(defun C:cc0 ( ) (command "chamfer" "distance" 0 0 "chamfer" "polyline" )
(princ "Polyline Chamfer at Distance 0-0" )(princ) )
(defun C:f116 ( ) (command "fillet" "radius" ".6875" "fillet" "Multiple" )
(princ "Multiple Fillet At 11/16 Inch " )(princ) )
(defun C:n ( ) (command "move" "p")
(princ "Move Previous" )(princ) )
All that other code is just gibberish to me. No offense intended.
Cheers!
CFK
