VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Extract text by zone from a block
5 REPLIES 5
jplujan
591 Views, 5 Replies
Hello
Would it be possible to extract a text (not attribute) from a user-defined area (blue dashed line) of a block?
With the attached code I can extract all the text in the block.
Sub Main()
    Dim objSeleccionRF As Object
    Dim NumeroColumna As String
    Set objSeleccionRF = SeleccionRF
    NumeroColumna = DevolverZona(objSeleccionRF)
End Sub
Function DevolverZona(seleccion As Object) As String
    Dim item As Variant
    Dim ent As Variant
    Dim SelectBlockText As Object
    Dim txt As AcadText
    For Each item In seleccion
        If TypeOf item Is AcadBlockReference Then
        Set SelectBlockText = ThisDrawing.Blocks("ZONE_DATA")
            For Each ent In SelectBlockText
                If TypeOf ent Is AcadText Then
                    Set txt = ent
                    Debug.Print ent.TextString
                    DevolverZona = ent.TextString
            Next
    Next
End Function
'''' SELECCION
Function SeleccionRF() As Object
    Dim seleccion As Object
    Set seleccion = NuevaSeleccion("SeleccionBloque")
    seleccion.SelectOnScreen
    Set SeleccionRF = seleccion
End Function
Function NuevaSeleccion(strNom As String) As AcadSelectionSet
   If SelectionExiste(strNom) Then ThisDrawing.SelectionSets.item(strNom).Delete
   Set NuevaSeleccion = ThisDrawing.SelectionSets.Add(strNom)
End Function
Function SelectionExiste(Nombre As String) As Boolean
    Dim Sset As AcadSelectionSet
    For Each Sset In ThisDrawing.SelectionSets
        If Sset.Name = Nombre Then
            SelectionExiste = True
            Exit Function
    Next Sset
End Function
Function DevolverSeleccion(cadena As String) As AcadSelectionSet
    Dim seleccion As AcadSelectionSet
    LimpiarSeleccion (cadena)
    Set seleccion = ThisDrawing.SelectionSets.Add(cadena)
    Set DevolverSeleccion = seleccion
End Function
Sub LimpiarSeleccion(ByVal cadena As String)
        Dim SSS As AcadSelectionSets
        On Error Resume Next
        Set SSS = ThisDrawing.SelectionSets
        If SSS.Count > 0 Then
            SSS.item(cadena).Delete
End Sub
Thanks in advance.
5 REPLIES 5
MakCADD
in reply to: jplujan
Verify the boundary is closed
Draw a RAY starting from the TEXT.
by counting the intersection points of a ray with boundary you can Verify the text is inside the boundary
ed57gmc
Assuming that the blue rectangle is just a selection window, you can use my GetSS_TextFilter function.
Ed
How to post your code.
Trae_A_Beall
in reply to: ed57gmc
If the blue window was not a Selection Window, but known X, Y coordinates instead, how would you extract all text from that region?
ed57gmc
in reply to: Trae_A_Beall
You can change acSelectionSetAll to acSelectionSetWindow and either prompt the user for window corners or supply them however you want.
Ed
jplujan
Thanks for your reply, I'll try it.
AutoCAD Inside the Factory
