You can easily find sample code of how to use IntersectWith() in VBA's documentation. With AutoCAD running:
1. Go to VBA editor (command "VBAIDE")
2. open Object Browser window
3. Select any object that has IntersectionWith method, such as AcadEntity, AcadLine, AcadCircle..., on the left side
4. Select IntersectionWith method on the right side
5. Click "?" on top of the Object Browser window. At this point, AutoCAD VBA help document window opens.
Here is the code copied from the VBA HELP document:
Sub Example_IntersectWith() ' This example creates a line and circle and finds the points at ' which they intersect. ' Create the line Dim lineObj As AcadLine Dim startPt(0 To 2) As Double Dim endPt(0 To 2) As Double startPt(0) = 1: startPt(1) = 1: startPt(2) = 0 endPt(0) = 5: endPt(1) = 5: endPt(2) = 0 Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt) ' Create the circle Dim circleObj As AcadCircle Dim centerPt(0 To 2) As Double Dim radius As Double centerPt(0) = 3: centerPt(1) = 3: centerPt(2) = 0 radius = 1 Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius) ZoomAll ' Find the intersection points between the line and the circle Dim intPoints As Variant intPoints = lineObj.IntersectWith(circleObj, acExtendNone) ' Print all the intersection points Dim I As Integer, j As Integer, k As Integer Dim str As String If VarType(intPoints) <> vbEmpty Then For I = LBound(intPoints) To UBound(intPoints) str = "Intersection Point[" & k & "] is: " & intPoints(j) & "," & intPoints(j + 1) & "," & intPoints(j + 2) MsgBox str, , "IntersectWith Example" str = "" I = I + 2 j = j + 3 k = k + 1 Next End If End Sub
HTH
