VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Country polylines
2 REPLIES 2
Ray-Sync
335 Views, 2 Replies
Country polylines
Ray-Sync
Hello, do you know if it is possible to extract the georeferenced territorial limits of a country to import them into AutoCAD as polylines using VBA?
jefferson
Country polylines
jefferson
2 REPLIES 2
daniel_cadext
in reply to: Ray-Sync
daniel_cadext
If you can use Python,  you may be be able to find something with geopandas
from pyrx_imp import Rx, Ge, Gi, Db, Ap, Ed
import traceback
import geopandas
def PyRxCmd_doit():
    try:
        db = Db.curDb()
        model = Db.BlockTableRecord(db.modelSpaceId(), Db.OpenMode.kForWrite)
        gdf = geopandas.read_file("E:/110m_cultural/ne_110m_admin_0_countries.shp")
        #do MultiPolygon first
        gdf0 = gdf.loc[gdf.geometry.geometry.type=='MultiPolygon']
        for mp in list(gdf0.geometry):
            for p in mp.geoms:
                pline = Db.Polyline(list(p.exterior.coords))
                pline.setColorIndex(1)
                pline.setClosed(True)
                model.appendAcDbEntity(pline)
        gdf1 = gdf.loc[gdf.geometry.geometry.type=='Polygon']
        for p in gdf1.geometry:
            pline.setColorIndex(2)
    except Exception as err:
        traceback.print_exception(err)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
import traceback
import geopandas
def PyRxCmd_doit():
    try:
        db = Db.curDb()
            for p in mp.geoms:
Ray-Sync
Ray-Sync
Thank you, @daniel_cadext
jefferson
jefferson
AutoCAD Inside the Factory
