VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
C # plugin retrieves setting information from the program
1 REPLY 1
288 Views, 1 Reply
1771245717
Observer
Observer
How to obtain configuration information from images in C # plugin development
1 REPLY 1
norman.yuan
in reply to: 1771245717
norman.yuan
You posted in wrong forum: this forum is AutoCAD VBA/COM API.
You should post in forums for AutoCAD Plant3D/P&ID and/or .NET forum (but you should clearly describe that your questions/issues are with AutoCAD Plant 3D/P&ID specific, which have nothing to do with plain AutoCAD .NET API.
Norman Yuan
Drive CAD With Code
Norman Yuan
Drive CAD With Code
AutoCAD Inside the Factory
