Zoom Extents for Saving Drawing Preview for Block Catalog
Message 1 of 9
I am trying to create a routine that will
-resize the active drawing window to 300 X 400
(pixels) and then
-perform zoom extents to include and maximize the
contents within the drawing so the it is displayed as large as possible in the
drawing preview
-lastly saving the drawing
I will use scriptpro to perform this routine on
multiple drawings.
The code I have written so far is as
follows:
Sub SDWMain()
'Size Document
Window
ThisDrawing.Width = 300
    ThisDrawing.Height =
400
ZoomExtents
  'The problem occurs here.  For some reason the
zoom extents does not correctly recognize the new window size?
End Sub
Anyone have any insight why this is not rendering
the desired effects?
Replies (8)
Message 2 of 9
I was playing around with window resizing a little while ago, and found a
couple of things....
- the Width and Height did not reset to exactly 300 and 400 in one step.
You may want to print out .Width and .Height after you do your resize. I
think it had something to do with toolbars, etc. If they don't go to what
you want, calculate the difference and size a second time to (.Width +/-
Difference). I know you didn't ask about this, but it's what came to mind.
http://groups.google.com/groups?selm=C1A35DF718C310208FFEB3797AD7D7FE%40in.W
ebX.maYIadrTaRb
Although I see now that this was based on the SCREENSIZE variable for some
reason... this may not affect you at all...
FWIW, Here's another person who seems to be in the same boat as you...
http://groups.google.com/groups?threadm=29F2D73049FB6581B2624049B861E2C0%40i
n.WebX.maYIadrTaRb
James
Message 3 of 9
James,
Thanks for the info. I'll check it out.
"James Belshan" wrote in message
news:73E45064962AA1FE7D5DE27A1A419387@in.WebX.maYIadrTaRb...
what
mind.
> ebX.maYIadrTaRb
> n.WebX.maYIadrTaRb
> James
Message 4 of 9
I acheived want I wanted with the
following:
Sub SDW()
ThisDrawing.Width =
300
ThisDrawing.Height = 400
ThisDrawing.SendCommand "zoom extents
ThisDrawing.Save
End Sub
> I was playing
> couple of
things....
> you want,
mind.
href="http://groups.google.com/groups?selm=C1A35DF718C310208FFEB3797AD7D7FE%40in.W">
face=Arial
si...
face=Arial size=2>> ebX.maYIadrTaRb
> reason... this may
href="http://groups.google.com/groups?threadm=29F2D73049FB6581B2624049B861E2C0%40i">
face=Arial
si...
face=Arial size=2>> n.WebX.maYIadrTaRb
> James
Message 5 of 9
I don't know why the orizinal way did not
work.  It seems this is some type of BUG?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
following:
Sub SDW()
ThisDrawing.Width =
300
extents "
ThisDrawing.Save
End
Sub
> I was playing
> couple of
things....
> you want,
mind.
face=Arial...
> Although I see now
> reason... this
face=Arial...
> James
Message 6 of 9
Your original code did not save the
drawing.
I assume this is where the preview gets reset(just
a guess)
So to me your first version looks much
different than this version.
Did you try
Sub SDW()
ThisDrawing.Width =
300
size=2>ZoomExtents
ThisDrawing.Save
End sub
to confirm that it was the send command that changed
the result?
BUG?
Message 7 of 9
Hi everyone,
When I tried the first version of
Brian's code, I had the same problem (not zooming extents). But when you
launch this code two times consecutively, you get the researched result...
Strange, no???
"Mark Propst" <nonentityatplanetkcdotcom> a écrit dans le message
de
href="news:016AC78D0DB80203920E1F013719B434@in.WebX.maYIadrTaRb">news:016AC78D0DB80203920E1F01371...
drawing.
reset(just a guess)
Did you try
Sub SDW()
ThisDrawing.Width =
300
size=2>ZoomExtents
ThisDrawing.Save
End sub
the result?
BUG?
Message 8 of 9
I tried that and it seems the application is not
recognizing that the drawing window size has changed.  I even tried adding
an update method.
drawing.
reset(just a guess)
Did you try
Sub SDW()
ThisDrawing.Width =
300
size=2>ZoomExtents
ThisDrawing.Save
End sub
the result?
BUG?
Message 9 of 9
I've tried this using Vlisp doing a
similar routine (without send comman) and I get the same
results.
Plug this in at the command line:
face=Arial size=2>
(vlax-put-property (vla-get-ActiveDocument
(vlax-get-acad-object)) 'Height 400)
(vlax-put-property
(vla-get-ActiveDocument (vlax-get-acad-object)) 'Width 300)
(vla-ZoomExtents
(vla-Save (vla-get-ActiveDocument
(vlax-get-acad-object)))
But if you try this inside Scriptpro ZoomExtents does
not work correctly, even if you double up the ZoomExtents
statement.
Hi everyone,
Strange, no???
de
href="news:016AC78D0DB80203920E1F013719B434@in.WebX.maYIadrTaRb">news:016AC78D0DB80203920E1F013...
drawing.
reset(just a guess)
Did you try
Sub SDW()
ThisDrawing.Width =
300
size=2>ZoomExtents
ThisDrawing.Save
End sub
changed the result?
BUG?
