Converting dvb to dll
Message 1 of 10
I know this was posted sometime ago but I can't find it. How do you convert
a .dvb file into a dll and then call it from AutoCAD vba?
Bill
Replies (9)
Message 2 of 10
You cannot *directly* compile a .dvb into a .dll. See our website for
details on what you want to do.
R. Robert Bell, MCSE
www.AcadX.com
"Bill Schoenhut" wrote in message
news:E270A850EE4CA7032629687FC421F1A1@in.WebX.maYIadrTaRb...
convert
| Thanks,
| Bill
Message 3 of 10
It won't be a straight port. You connect to AutoCAD in a different way
and there is no ThisDrawing object. Also, any forms in your DVB will
have to be completely rewritten.
Once compiled, you use the DLL just like any other library: reference
it, instantiate an object supplied by the DLL and manipulate the object
via its properties and methods.
"It is more important that you know how to find the answer than to have
the answer" - Me
http://code.acadx.com
Message 4 of 10
Frank,
Do you know of a comprehensive explanation anywhere re: the
benefits/penalties of doing this? In process servers, etc.? I'm not clear on
this subject and would like to figure it all out.
Dale
"Frank Oquendo" wrote in message
news:E2E251ADC1678CE8F48FE6A3D3F8214F@in.WebX.maYIadrTaRb...
convert
> the answer" - Me
Message 5 of 10
I haven't re-read our article in awhile, but it might explain the benefits.
http://code.acadx.com/articles/003.htm
www.AcadX.com
"Dale Levesque" wrote in message
news:530B17BFCB4DCB40E046511A64675642@in.WebX.maYIadrTaRb...
| Frank,
on
| Dale
| convert
| > the answer" - Me
Message 6 of 10
After following the instructions for creating a DLL at
http://code.acadx.com/ (which is what I did), have your main function in
your class module accept the application object. Like this:
Public Sub g_sb_MySub(ao_AcadApp As AcadApplication)
Blah blah ...
End Sub
Then call it like this from your acad.dvb stub:
Public Sub g_sb_Stub()
Dim MyDLL As New clsDLL
MyDLL .g_sb_MySub ThisDrawing.Application
End Sub
The reason I put my large DVB file into a DLL was so that I could utilize
our versioning software on the project. It just wasn't possible when
everything was stored in a binary DVB file.
Dale
convert
> Thanks,
> Bill
Message 7 of 10
Every Windows applciation is a given its own 2GB memory segment. This is
called a process space. All process spaces are mapped into physical and
virtual memory so the same memory address in one space does not
correspond to the same physical address in another.
That means that when two applications want to share data, Windows has to
match up the addresses and shuttle the data across those process
boundaries. This is called marshalling and it's an expensive procedure.
However, an in-process server is an applciation which gets loaded into
the same process space as the calling application. Thanks to the fact
they share the process space, the in-process server ahs direct access to
the calling application's data alleviating the need to marshal that data.
The obvious benefit is speed as anyone who has ever used an ActiveX exe
as an AutoCAD controllers can tell you.
the answer" - Me
Message 8 of 10
Thanks! That must mean that a VBA app is in process as well?
news:C6D48F8814FBD8362257F4FAD2A92D92@in.WebX.maYIadrTaRb...
clear on
> the answer" - Me
Message 9 of 10
You're welcome. And yes, it is.
the answer" - Me
Message 10 of 10
Thanks.
news:4E3AF21100C5928836386AADB8931824@in.WebX.maYIadrTaRb...
> Blah blah ...
> End Sub
> End Sub
> Dale
> convert
> > Thanks,
> > Bill
