XReference Path
XReference Path
XReference Path
How do you retrieve the path of an XRef using VBA in A2K? Using Autodesk's
examples, I can create a list of Xref names using IsXref but I haven't had
much luck figuring out how to create a list of Xref path's.
TM Amick II
The path property of the AcadExternalReference
object returns the fullpathname of an XRef
Denis
I'm aware of this property. My problem is that I have been unsuccessful at
getting the command syntax correct.
TM
Denis Gagne wrote in message
news:893s57$mre10@adesknews2.autodesk.com...
> Denis
TM
The path property will work only on an AcadExternalReference
found in the modelspace collection:
Dim oEntity As AcadEntity
For Each oEntity In ThisDrawing.ModelSpace
If TypeOf oEntity Is AcadExternalReference Then
ListBox1.AddItem (oEntity.Path)
End If
Next
Curiously the pathName information contained in an XRef block
record was not exposed to VBA. If, in your drawing, there's no
AcadExternalReference (suppose it has been deleted accidently),
I'm afraid there's no way to get the pathname of your XRef block
from VBA.
If the AcadExternalReference was inserted without retaining the
fullpathname, the path property won't return any path but only
the name of the referenced drawing
I can't see either how we could create an AcadExternalReference
from an XRef block. Very amazing.
Denis
TM Amick II a écrit dans le message :
893tv6$mqa17@adesknews2.autodesk.com...
> TM
> > Denis
Thanks Denis. That worked like a charm.
news:894ec0$otb8@adesknews2.autodesk.com...
> TM
> End If
> Next
> from VBA.
> Denis
at
> > TM
> > > Denis
This is a pain, but it will work:
Use the insert method of the block object. This will give you an
AcadBlockReference that can be cast as AcadExternalReference, from which you
can get the path.
Then delete the AcadBlockReference:-(
