Raising Errors in VBA
Is there a way I can set my project's error trapping to break on unhandled
errors without actually going into the tools/options menu in the editor?
Since VBA defaults to break in the class module, whenever I try to raise an
error, my macro crashes at that point instead of going up the call stack.
Jeff
Try something like this
Sub LayerToggle()
Dim currLayer As AcadLayer
Dim newlayer As AcadLayer
Dim lNameLength As Long
Dim sName As String
Dim sRtName As String
On Error GoTo Err_LayerToggle
[notice the above always occurs prior to the real code]
[notice below normally occurs after the real code]
Exit_LayerToggle:
' Clears memory for use by other programs
Set currLayer = Nothing
Set newlayer = Nothing
Exit Sub
Err_LayerToggle:
MsgBox Err.Description
Resume Exit_LayerToggle
End Sub
The above is basic error trapping, I do this in every routine I write.
Good luck,
Eric
Jeff Uhlir wrote in message
news:8920jr$fep61@adesknews2.autodesk.com...
an
> Thanks,
> Jeff
Thanks Eric,
I acutally take things a step further by raising errors in my error handlers
so that they can get handled in the calling procedure. This way I can
handle all of my application-specific errors in one routine. I do something
like this:
Private Sub ChildProc
On Error GoTo ErrHandler
If then
Err.Raise ERR_NUMBER,"ChildProc",ERR_DESCRIPTION
Exit_ChildProc:
Exit Sub
ErrHandler:
With Err
If .Number = ERR_NUMBER Then
.Raise .Number, .Source, .Description
Else
Msgbox Err.Description
Exit With
Resume Exit_ChildProc
Exit Sub
When error trapping is set to "Break on Unhandled Errors", this works fine.
However, every time VBA is initialized, error trapping goes back to the
"Break in Class Module" setting. When in this default setting, errors
raised in error handlers get treated like a regular run time error
(application crash).
If anyone knows how I can set the default error trapping
(Options/Tools/General Tab) to "Break on Unhandled Errors", I would greatly
appreciate it. Thanks
Jeff
eric wrote in message
news:8927g5$i216@adesknews2.autodesk.com...
> Sub LayerToggle()
> Dim sName As String
> Exit_LayerToggle:
> Exit Sub
> Err_LayerToggle:
> End Sub
> Good luck,
> Eric
unhandled
> an
stack.
> > Thanks,
> > Jeff
Try putting something like
Debug.Assert False
just after
You can force a breakpoint this way that will survive closing the project
and all references to Debug are automatically removed when the project is
compiled.
--Bill
Jeff Uhlir wrote in message <893en5$klf6@adesknews2.autodesk.com>...
>Thanks Eric,
handlers
something
>like this:
> If then
> End If
>Exit_ChildProc:
> Exit Sub
>ErrHandler:
> With Err
> Else
> End If
> Exit With
>Exit Sub
>Jeff
>> Sub LayerToggle()
>> Dim sName As String
>> Exit_LayerToggle:
>> Exit Sub
>> Err_LayerToggle:
>> End Sub
>> Good luck,
>> Eric
>unhandled
editor?
raise
>> an
>stack.
>> > Thanks,
>> > Jeff
There are certain errors that I raise within my validation routine that I
handle differently depending on what the calling procedure is. Becasue of
this, I handle these errors in their respective calling procedures. To do
this, I use the Err.Raise method inside my validation routine to send the
error back up to the calling proc. Since this validation routine is inside
a class module, it halts execution when it reaches an Err.Raise within an
error handler (because error handling is set to "Break in Class Module" by
default). When the error trapping behavior of VB is set to "Break on
Unhandled Errors", the error is correctly sent back to the calling routine
where it is dealt with properly.
Whenever VBA is initialized, the error trapping behavior of VB is set to
"Break in Class Module". I need a way to set the error trapping to "Break
on Unhandled Errors" either through code or some other way. Otherwise, each
time VBA is initialized, the VB Editor has to be opened and error trapping
manually set.
Sorry for the confusion...
Jeff
Bill Daly wrote in message
news:893mts$klf17@adesknews2.autodesk.com...
> Debug.Assert False
> just after
> compiled.
> --Bill
> >Thanks Eric,
> handlers
> something
> >like this:
> > If then
> > End If
> >Exit_ChildProc:
> > Exit Sub
> >ErrHandler:
> > With Err
> > Else
> > End If
> > Exit With
> >Exit Sub
fine.
greatly
> >Jeff
> >> Sub LayerToggle()
> >> Dim sName As String
> >> Exit_LayerToggle:
> >> Exit Sub
> >> Err_LayerToggle:
> >> End Sub
> >> Good luck,
> >> Eric
> >unhandled
> editor?
> raise
> >> an
> >stack.
> >> > Thanks,
> >> > Jeff
