Writing Ordinate Dimensions to Excel File
Thomas.Long
Message 1 of 8
Thomas.Long
So I'm fairly new to visual basic (less than a month of experience, please bear with me) so I apologize in advance if anything I ask for is stupid.
I have a secondary program that I want to port in the dimensions from an autocad file. Having them communicate directly is a bit over my head. However, I can make the other program observe the number of rows and port in the dimensions in excel.
That being said, what I'm looking for is to:
1) Look in a specified location for a given file name, and delete it if its already there
2) Generate a new excel file with the same name
3) Select an unspecified number of ordinate dimensions and export them to the excel file
4) Change the dimensions from feet and inches (architectural) into just inches (decimal style)
The first two steps were just because I wanted to make absolutely sure that the file was always clean and when used would never accidentally have dimensions left over from previous uses.
The example of the desired output I just ignored the 0 dimension as we wont be selecting that.
Thank you all very much in advance and I apologize if anything I asked for was particularly stupid.
Replies (7)
Message 2 of 8
Thomas.Long
I've cobbled this together from some different codes I've found online, but I'm running into an issue. If anyone ever uses escape to exit the command then it doesn't close the excel file. This means the excel file is simultaneously open and not open, and I have no idea how to close it from inside the program.It's currently deleting the old file, creating a new one, and writing the dimensions to it. I just need to know how to fix this error now, because as it stands if it exits incorrectly it won't let you open the file because it says another user is using it (yourself) but it won't let you close the file because you don't actually have it open.
Option Explicit
Sub Main()
Dim oExcel As Object
Dim oBook As Object
Dim oSheet As Object
'Start a new workbook in Excel
Set oExcel = CreateObject("Excel.Application")
Set oBook = oExcel.Workbooks.Add
Set oSheet = oBook.Worksheets(1)
Dim FileName As String
FileName = "H:\Beam Locations.xlsx"
If Not Dir(FileName) = "" Then Kill (FileName)
'Save the Workbook and Quit Excel
oBook.SaveAs FileName
Call SortDims(FileName, oExcel, oBook, oSheet)
oExcel.Save
oExcel.Quit
End Sub
Function SortDims(strFileName, xlApp, xlBook, xlSheet)
Dim oSset As AcadSelectionSet
Dim oEnt As AcadEntity
Dim oDim As AcadDimension
Dim oDimOrd As AcadDimOrdinate
Dim eCnt As Integer
Dim iCnt As Integer
Dim rCnt As Integer
Dim iNdx As Integer
Dim insPnt() As Double
Dim fcode(0) As Integer
Dim fdata(0) As Variant
Dim dxfCode, dxfdata
fcode(0) = 0: fdata(0) = "DIMENSION"
dxfCode = fcode
dxfdata = fdata
Set oSset = ThisDrawing.PickfirstSelectionSet
oSset.Clear
oSset.SelectOnScreen dxfCode, dxfdata
iCnt = oSset.Count
ReDim SelPnt(0 To iCnt - 1, 0 To 3) As Variant
eCnt = 0
For Each oEnt In oSset
Set oDim = oEnt
insPnt = oDim.TextPosition
SelPnt(eCnt, 0) = insPnt(0)
SelPnt(eCnt, 1) = insPnt(1)
SelPnt(eCnt, 2) = insPnt(2)
Set oDimOrd = oEnt
SelPnt(eCnt, 3) = oDimOrd.Measurement
eCnt = eCnt + 1
Next oEnt
ReDim sortPnt(0 To iCnt - 1, 0 To 3) As Variant
sortPnt = ColSort(SelPnt, 1)
Dim irow As Long
irow = 1
With xlSheet
.Range("A:A").NumberFormat = "0.00#"
For iNdx = 0 To UBound(sortPnt, 1)
.Cells(irow, 1) = CStr(sortPnt(iNdx, 3))
irow = irow + 1
Next iNdx
End With
End Function
Public Function ColSort(SourceArr As Variant, iPos As Integer) As Variant
Dim Check As Boolean
ReDim tmpArr(UBound(SourceArr, 2)) As Variant
Dim iCount As Integer
Dim jCount As Integer
Dim nCount As Integer
iPos = iPos - 1
Check = False
Do Until Check
Check = True
For iCount = LBound(SourceArr, 1) To UBound(SourceArr, 1) - 1
If SourceArr(iCount, iPos) > SourceArr(iCount + 1, iPos) Then
For jCount = LBound(SourceArr, 2) To UBound(SourceArr, 2)
tmpArr(jCount) = SourceArr(iCount, jCount)
SourceArr(iCount, jCount) = SourceArr(iCount + 1, jCount)
SourceArr(iCount + 1, jCount) = tmpArr(jCount)
Check = False
Next
Next
Loop
ColSort = SourceArr
End Function
Message 3 of 8
Ed__Jobe
Working with Excel using COM, you need to explicitly dispose of any objects you create, such as oExcel, oBook and oSheet. You also, have to dispose of them in the opposite order in which you create them, i.e.
Set oSheet = Nothing
Set oBook = Nothing
Set oExcel = Nothing
Ed
How to post your code.
Message 4 of 8
Thomas.Long
Is that why its generating two extra files? I'm getting an extra file called resume.xlw in my C:\Users space and one called FileName there as well.
Message 5 of 8
Ed__Jobe
Possibly. Try deleting them and see if they reappear after you run your program again.
Ed
Message 6 of 8
Thomas.Long
They do. I've pretty much got the program running with one slight error. If I exit the function early it doesn't exit excel. I'm trying to finish it off with a keystroke check command that says if you hit the escape key to close excel, but I'm not quite sure hot to place it. Everything works perfectly except the two lines commented out directly under Sub Export(). Those are the two lines I hope to use to make some form of command to exit on the statement.
Right now, if I run the code all the way through it works flawlessly. However, if I hit escape to exit the command it never closes the excel function and so to access the file I have to use task manager to end the process manually.
Option Explicit
Sub Export()
'Dim KeyAscii As MSForms.ReturnInteger
'If Asc(Chr(KeyAscii)) = 27 Then
If Not Dir("C:\Users\" & Environ$("Username") & "\Documents\RESUME.XLW") = "" Then Kill ("C:\Users\" & Environ$("Username") & "\Documents\RESUME.XLW")
Dim oBook As Object
If Not Dir("H:\Beam Locations.xlsx") = "" Then Kill ("H:\Beam Locations.xlsx")
oBook.SaveAs "H:\Beam Locations.xlsx"
Call SortDims("H:\Beam Locations.xlsx", oExcel, oBook, oSheet)
oExcel.Save
oExcel.Quit
Set oBook = Nothing
End Sub
Dim eCnt As Integer
Dim iCnt As Integer
Dim rCnt As Integer
Dim iNdx As Integer
dxfCode = fcode
dxfdata = fdata
oSset.Clear
iCnt = oSset.Count
eCnt = 0
Set oDim = oEnt
Set oDimOrd = oEnt
eCnt = eCnt + 1
Next oEnt
Dim irow As Long
irow = 1
With xlSheet
irow = irow + 1
Next iNdx
End With
End Function
iPos = iPos - 1
Check = False
Do Until Check
Check = True
Check = False
Next
Next
Loop
ColSort = SourceArr
End Function
Message 7 of 8
Ed__Jobe
This post will help with the ESC key, but not all cases that might cancel a command.
Ed
Message 8 of 8
Thomas.Long
Thank you! That worked perfectly! Posting in case anyone else needs to port ordinate dimensions to an excel file.
Option Explicit
Sub Export()
    On Error GoTo ErrorHandler
    Dim oBook As Object
    oExcel.Save
    oExcel.Quit
    Set oBook = Nothing
ErrorHandler:
    If Err.Number = -2147352567 Then
        oExcel.Save
        oExcel.Quit
        Set oBook = Nothing
        Exit Sub
End Sub
    Dim eCnt As Integer
    Dim iCnt As Integer
    Dim rCnt As Integer
    Dim iNdx As Integer
    dxfCode = fcode
    dxfdata = fdata
    oSset.Clear
    iCnt = oSset.Count
    eCnt = 0
        Set oDim = oEnt
        Set oDimOrd = oEnt
        eCnt = eCnt + 1
    Next oEnt
    Dim irow As Long
    irow = 1
    With xlSheet
            irow = irow + 1
        Next iNdx
    End With
ErrorHandler:
        xlApp.Save
        xlApp.Quit
        Set xlSheet = Nothing
        Set xlBook = Nothing
        Set xlApp = Nothing
        Exit Function
End Function
    iPos = iPos - 1
    Check = False
    Do Until Check
        Check = True
                    Check = False
                Next
        Next
    Loop
    ColSort = SourceArr
End Function
