HOW TO ENTER COMMANDS IN AUTOCAD2016 USING VB.NET
HI,
     Actually I want to insert commands using VB.NET. But the two dll are missing acmgd.dll and acdbmgd.dll. How to get these dlls for create the connection VB.NET and AutoCAD. Please any suggestion please let me know.
Thanx
Mohit
Alfred.NESWADBA
add them by adding references to your project, the files can be found in the program folder for AutoCAD. Don't set it to "copy local"
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanx for reply
But I am searching in COM refference but the both dlls are not there. So how to add those dlls.
Alfred.NESWADBA
You mentioned in your first post:
Sorry, these DLL's are no COM dll's, they are for managed access.
If you only need COM then you don't need the DLL's you mentioned in your first post, you only need these two references:
  • ACAD 20XX Type Library
  • AutoCAD/ObjectDBX Common XX.X Type Library .... for AutoCAD 2016 you need the version 20.0
(sorry for German Screenshot)
- alfred -
Alfred NESWADBA
Thanx for your reply
But please tell that how to pass command "INSERT" from VB.NET to AutoCAD 2016. Please give the syntax or some small example.
Thanx
Mohit
Alfred.NESWADBA
Show what you have, I'm even not sure why you are working based on COM (is it an external application or does it run in-process and so better using the manged interface)Please give the syntax or some small example?).
Why do you want to send commands instead of using the API to insert block-references? It's the last alternative when everything else fails/is not possible as you don't get a feedback about it failed or worked ...
Let us know more about what you do and show us what you have currently.
- alfred -
Alfred NESWADBA
