Draw a 3D Circle with VBA
OceanaPolynom
OceanaPolynom
Hello
I need to use VBA to draw 3D circles in model space.  The circles are given by the center point (X Y Z), the radius, and a direction (in radians) from the center point.  I don't have much 3D experience.
Thank you,
John
Alfred.NESWADBA
a sample is shown in the help: >>>click<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
OceanaPolynom
Hello
This will not solve my problem, but it might be the start of a solution.  The circles represent steel rings used to reinforce a tunnel as it is being constructed.  The rings must be oriented at 90 degrees to the alignment in the z direction, and at right angles to the alignment whether in a straight section or a curved section.  I have attached a file that I created using AutoCad commands.  The direction (or vector?) that is included in the input data is used to define the circular plane of the ring.
Thank you,
John
Alfred.NESWADBA
That was what I was able to see from your initial post ... 😉
Look to the TranslateCoordinates function (>>>click<<<) as well as to the definition of user-coordinate-systems (>>>click<<<) for your circles along alignments.
- alfred -
Alfred NESWADBA
OceanaPolynom
Thank you I am working on this now
John
OceanaPolynom
Thank you very much.  In the end I only needed to use
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPnt, yAxisPnt, "New_UCS")
in the right way in order to draw the circles.
Thanks again
John
