try this
'make sure to start listbox indexes @ 0 open "somefile.txt" for input as #1 i&=0 do input #1,a$ MyListBox.AddItem (a$), (i&) i&=i&+1 loop until eof(1)
good luck
John
Thanks, John it's working but i need import some column. Can You show me how?
Sorry, I don't understand. Do you mean a specific column in a text file. Post an example if you can.
John
Ok, I have more column to import and i need import all column.
Empty columns also...
Example in attachment.
Example have 40 column.
Now I use this code...
Dim fileName As String: fileName = "V:\CADCAM-PACK\save\test.txt" Dim fileNo As Integer: fileNo = FreeFile Dim r As Double: r = 0 Dim data As String: Dim col As Integer: Dim row As Integer: row = -1 Dim rr As Integer: rr = -1 Dim EmptyList() As Double Open fileName For Input As #fileNo Do Until EOF(1) Line Input #fileNo, data row = row + 1 Loop Close #fileNo ReDim EmptyList(0 To row, 0 To 39) As Double prof_men.profle_listprof.list = EmptyList Open fileName For Input As #fileNo Do Until EOF(1) col = 0: rr = rr + 1: r = 0 Line Input #fileNo, data For i = 1 To Len(data) If Mid(data, i, 1) = Chr(9) Then If r = 0 Then prof_men.profle_listprof.list(rr, col) = Mid(data, 1, i - 1): r = i: col = col + 1: GoTo pom1: If Mid(data, i, 1) = Chr(9) Then If col = 39 Then prof_men.profle_listprof.list(rr, col) = Mid(data, i + 1, Len(data) - (Len(data) - r)): r = 0: col = -1: Exit For If Mid(data, i, 1) = Chr(9) Then If r <> 0 Then prof_men.profle_listprof.list(rr, col) = Mid(data, r + 1, i - r): r = i: col = col + 1: pom1: Next Loop Close #fileNo If prof_men.Visible = False Then prof_men.show
or maybe that
Sub fromF() Dim itab() As Variant Dim r&, ir&, c&, dane$ Filename = "d:\demo\testlst.txt" fileNo = FreeFile Open Filename For Input As #fileNo While Not EOF(fileNo) Line Input #fileNo, dane r = r + 1 Wend Close #fileNo ReDim itab(r, 0) ir = 0: c = 0 Open Filename For Input As #fileNo While Not EOF(fileNo) Line Input #fileNo, dane n = UBound(Split(dane, Chr(9))) If n > c Then c = n ReDim Preserve itab(r, c) For i = 0 To n itab(ir, i) = Split(dane, Chr(9))(i) Next ir = ir + 1 Wend Close #fileNo kok.lst.List = itab End Sub
but its too slow... : |
I would suggest to speed up your code is to remove the ReDim Preserve itab(r,c) from the while loop.
Imagine that ReDim Preserve is VBA needs to define a new array and new size then copy every thing from the old to new.
Once or twice may be ok but every time for each line read is a lot of work.
In the previous lines the code determines the number of rows r by counting each line entry.
Do the same thing to determine the maximum columns c.
Then define size of the array itab(r, c). ReDim Itab(r,c)
Then reopen the file and populate the array, without the ReDim Preserve function.
I hope this helps.
