Why is Plotting in VBA so slow
Message 1 of 9
Why is Plotting in VBA so slow. Are there any workarounds for this.
Here is the print routine that I am using. Later I am going to loop this through many drawings. Using ACAD 2007
Here is the code.
Sub Printdrawing()
ThisDrawing.ActiveLayout.ConfigName = "\\Tasdc01\HP Laserjet 8000 Series PCL"
ThisDrawing.ActiveLayout.PlotWithPlotStyles = True
ThisDrawing.ActiveLayout.StyleSheet = "TAS-Std.ctb"
ThisDrawing.ActiveLayout.GetWindowToPlot Min, Max
ThisDrawing.ActiveLayout.SetWindowToPlot Min, Max
ThisDrawing.ActiveLayout.PlotType = acWindow
ThisDrawing.ActiveLayout.SetCustomScale 1, BScale
ThisDrawing.ActiveLayout.CanonicalMediaName = "11x17"
'ThisDrawing.Plot.DisplayPlotPreview acFullPreview
ThisDrawing.Plot.PlotToDevice
End Sub
Replies (8)
Message 2 of 9
Turn off background plotting.
Rant #1: Why are you still plotting by window? What is wrong with using the
Layout option? If you used the Layout option, you could use Publish and get
rid of your code. Then, if you can use Publish, you make it easy to use SSM
to publish your sets.
R. Robert Bell
wrote in message news:5417362@discussion.autodesk.com...
Message 3 of 9
R. Robert Bell said the following On 12/7/2006 9:14 AM:
Amen to that....
R.K. McSwain
http://rkmcswain.blogspot.com
Message 4 of 9
I would love to, unfortunately I inherited 6 years of cad data with no standards what so ever. The only consitent thing about all of the drawings is the title block. I have setup standards and so forth for all future (New) projects, but as far as our existing standard product lines I have to deal with what I got.
Therefore in this routine I am finding the bounding box of the border and it's scale factor. I am then using this to set my print setting to print it out.
I love the publish command and works on all of our new drawings(The ones that got done since I took over.)
Zuccus
Message 5 of 9
Sorry,
Forgot to mention that turning off the background plotting was the answer to my question thanks.
Zuccus
Message 6 of 9
Correct me if there's a way of doing this, but it's because the scale to
fit option & centre plot options are greyed out so can't print down to
A3 or even accurately at A1.
Ta
Dave F.
Message 7 of 9
Do you mean that you have a layout that is set up to plot to a larger sheet,
and you run into trouble when you want to plot that layout reduced?
If that is where you are hung up, it means that you haven't created a name
page setup that does the reduced plot, just by selecting it.
I'm attaching a drawing where the layout plots in Arch E1 size (sorry, I'm
in the US). But if we want to plot to an 11x17, we simply run the plot
command and select the 11x17 page setup. Don't need to change the layout
itself, don't need to window, or center, or fit.
Took a small bit of work up front, to determine the needed settings to get a
good 11x17 plot, but once I did, and added it to the template, I'm done.
R. Robert Bell
"Dave F." wrote in message
news:5419498@discussion.autodesk.com...
> the
> get
> SSM
Ta
Dave F.
Message 8 of 9
I have a lout with an ISO A1 size title block. I sometimes want to print
it out on paper of size ISO A3, which is smaller.
Only if I were to use the Layout option of the Plot Area in the plot dialog.
Yes I have, but I've set them to plot to Extents instead of Layout
because it allows me to plot to "fit to paper" which, as I said, is
greyed out when using Layout.
> in the US).
That's OK, I forgive you 🙂
Believe me, to reduce the size of the plot, it's much easier using
Extents/Plot to Fit. None of the tedious fiddling about that you
obviously had to do to work out a custom scale of 1:3.899 & a Y offset
of 0.1723!
No matter what printer you send it to, Plot to Fit will ensure it fits
on the paper!
I work in a company that has a dozen different printers all with
different margin sizes. To work out the custom scale for each of them,
as you did, would be a waste of time.
Cheers
Dave F.
Message 9 of 9
It wasn't as bad as you make it out. Take the worst-case margins. An Excel
spreadsheet gave me all the needed parameters in less than 10 minutes.
R. Robert Bell
news:5420651@discussion.autodesk.com...
...Believe me, to reduce the size of the plot, it's much easier using
of 0.1723!
on the paper!
