List names of BlkRefs selected.
Message 1 of 21
After typing all this i was begining to think it was long-winded so I'll trying to simplify here. I have an string array that contains block.names some of these substrings are the same. I want to filter this array so there's only one of each substring.
I think I found a function to help me:
Filter(sourcesrray, match[, include[, compare]])
but I'm unsure on how to implement it.
Long Version:
First I'll explain the "work-around" I have implemented so maybe you can see what i'm trying to do.
I have this tool that skips through blocks of the same name, zooming into each one individualy. The user can select which block he/she wants from a ComboBox that contains a list of blocks defined.
I get this list by iterating throught the Blocks collection, which shows blocks defined in the WHOLE drawing, and add Block.Names to a string array ONLY if there is a reference to it on the ActiveLayout. which means I have to make a SelectionSet of EVERY block defined in the drawing, filter that SelectionSet, and then if the SelSet.Count <> 0, I add that Block Name to the array. In a drawing with 150+ different blocks defined this is very inefficient and sloppy, but it's working.
Now I have the time and want to spruce this thing up a bit and I've come to a roadblock.
Instead of using the Blocks Collection i'm letting the user select the block refs to list. So the user makes this SelSet containing mutiple copies of, say, ten different block defintions. So I have this potential list but some blocks are listed many times. I need to widdle this down to one Block.Name string for each block in this array and then I can add it to the ComboBox.
Replies (20)
Message 2 of 21
Well, don't use an array.
If you use a scripting dictionary, you can On Error Resume Next on the error
when attempting to add an item that already exists, and then use the Keys
method to feed the ComboBox. Obviously create a function to attempt the Add,
due to the On Error.
R. Robert Bell
wrote in message news:5417239@discussion.autodesk.com...
Long Version:
a roadblock.
Message 3 of 21
I was afraid this might happen. I don't know what a scripting dictionary is. I wouldn't say I'm absolute beginner when it comes to VBA customization, but I not exactly a pro. Basically I've learned to get a round using Help. And according to Help, ComboBox doesn't have a Keys method.
Would you bother to tell me if I'm on the right track with the Filter function?
Message 4 of 21
Sorry I missed the part about not using an array. Ok, what's a scripting dictionary?
Message 5 of 21
It is the Dictionary object that is part of Microsoft's Scripting Runtime.
You add a reference to your project for the runtime, and then you can create
and use the Dictionary. It has the Keys method, which returns an array of
the keys (index) for the items stored in the dictionary.
See attached sample (assumes 2007).
R. Robert Bell
wrote in message news:5417325@discussion.autodesk.com...
dictionary?
Message 6 of 21
I get an runtime error(see attached), I think this is because ComboBox.List is expecting a variant array.
Message 7 of 21
No, that error is coming from an attempt to set the list index, i.e.
selecting the first item.
Just remove, or comment out, the line that does that. I suspect you are
running the code on a layout with no blocks inserted.
R. Robert Bell
wrote in message news:5418427@discussion.autodesk.com...
Message 8 of 21
arcticad
The value of pBlock.EffectiveName is not valid. Something is a miss.
(defun botsbuildbots() (botsbuildbots))
Message 9 of 21
Are you running the code in 2007? EffectiveName was part of an interface,
not the BlockReference object, before 2007.
R. Robert Bell
wrote in message news:5418877@discussion.autodesk.com...
Message 10 of 21
arcticad
I'm running in Autocad 2005
Message 11 of 21
Then change EffectiveName to just Name. There were no dynamic blocks in
2005, right?
R. Robert Bell
wrote in message news:5419449@discussion.autodesk.com...
Message 12 of 21
Same here. I'm also using 2005.
Message 13 of 21
Again, just change EffectiveName to Name.
And the next time I state that a sample assumes 2007, it would be nice if
you said "there's an error, but I'm running 2005." There just might be a
reason I said the code assumes AutoCAD 2007.
R. Robert Bell
wrote in message news:5419723@discussion.autodesk.com...
Message 14 of 21
Instead of using the "tripped up" method of On Error, why not use the
.Exist method that's built in.
If someone's gone to the trouble of programming it, it seems rude not to
use it:
If myBlocks.Exists(aBlock.name) = False Then 'block name not stored
Dave F.
Message 15 of 21
Sounds good to me.
R. Robert Bell
"Dave F." wrote in message
news:5420602@discussion.autodesk.com...
use it:
Message 16 of 21
Like so...
If Not myBlocks.Exists(aBlock.Name) = False Then
AddBlock myBlocks, aBlock
Message 17 of 21
No.
If Not (myBlocks.Exists(aBlock.EffectiveName)) Then _
myBlocks.Add aBlock.EffectiveName, aBlock
or
R. Robert Bell
wrote in message news:5422866@discussion.autodesk.com...
Like so...
Message 18 of 21
Of course, change EffectiveName to just Name for AutoCAD 2005.
R. Robert Bell
"R. Robert Bell" wrote in message
news:5423098@discussion.autodesk.com...
No.
or
Message 19 of 21
I tryed to incorporated the code into my application, and I get a compile error:
"user-defined type not defined"
with this part of code highlighted:
"myBlocks As New Scripting.Dictionary"
Message 20 of 21
Check your references
you need the scripting runtime
wrote in message news:5423121@discussion.autodesk.com...
error:
