Why does my VBA function generate a blank PDF for one DWG file but work fine for another?
sonchai_n
sonchai_n
I have a VBA Excel function that plots a selected area to PDF using DWG To PDF.pc3. The function works correctly for one DWG file, generating a properly formatted PDF, but when I run it on another DWG file (with the same settings and details), the resulting PDF is blank.
Here is my function:
Function TestPlotSelectedAreaToPdf() As Boolean
    On Error GoTo ErrorHandler
    acadDoc.SetVariable "BACKGROUNDPLOT", 0
    Dim plotFileName As String
    plotFileName = "D:\Test\TestPlotSelectedArea.pdf"
    Dim lowerLeft(0 To 1) As Double
    Dim upperRight(0 To 1) As Double
    lowerLeft(0) = 0#: lowerLeft(1) = 0#
    upperRight(0) = 297#: upperRight(1) = 210#
    With acadDoc.ActiveLayout
        .configName = "Acade - DWG To PDF.pc3"
        .CanonicalMediaName = "ISO_full_bleed_A4_(297.00_x_210.00_MM)"
        .plotType = acWindow
        .SetWindowToPlot lowerLeft, upperRight
        .centerPlot = True
        .StandardScale = acScaleToFit
        .plotRotation = ac0degrees
        .PlotWithPlotStyles = True
        .RefreshPlotDeviceInfo
    End With
    acadDoc.Plot.PlotToFile plotFileName
    TestPlotSelectedAreaToPdf = True
    Exit Function
ErrorHandler:
    Debug.Print "Error TestPlotSelectedAreaToPdf : " & Err.Description
    TestPlotSelectedAreaToPdf = False
End Function
Additional Info:
  • Both DWG files contain similar objects and layers.
  • The PDF output for one file is correct, while the other file generates a blank PDF.
  • No errors occur during execution.
  • File Test1.dwg can ploted to pdf
  • File Test2.dwg can ploted to pdf but is blank pdf
What could be causing this issue? Are there any settings in the DWG file that might affect the plot result?
Ed__Jobe
Since you didn’t post the dwg that plots blank, I can only guess that there’s nothing in the area of the window. Since you plot the ActiveLaout, it’s up to the user to make sure that the desired layout is active and that model or paper space is correct.
Ed
How to post your code.
Ed__Jobe
Sorry it took me so long to respond. In Test2, the problem is simply that you put the entities on the Defpoints layer, which is non-plotting.
Ed
sonchai_n
Thank you for your response!
I have checked the Defpoints layer, and I can confirm that my entities are not on that layer.
However, the issue still persists. When I use the same VBA function to plot Test2.dwg, the selected Window area is not applied correctly, which results in a PDF that does not match the expected output.
What I have verified:
  • Objects are not on the Defpoints layer.
  • The SetWindowToPlot coordinates are correct.
  • The plot configuration is the same for both DWG files.
  • Other DWG files with the same settings plot correctly.
What could be causing this issue? Are there any settings in AutoCAD that might affect how the plot window is applied?
Thanks again for your help! 😊
Ed__Jobe
I've looked over the code and made some minor changes but Test2 still won't accept setting the plot window. If you start the PLOT command and manually set the window, you will notice that there is no plot area set. The PLOT command is able to set the window, but the code isn't setting it. I would run the VARS2CR command on each file and compare them to see if test2 has something set differently. If not, it may just be a corrupt file. I ran the AUDIT command, but it didn't find any  problems.
Sub TestPlotSelectedAreaToPdf()
    ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
    plotFileName = Left(ThisDrawing.Name, Len(ThisDrawing.Name) - 4) '"D:\\Test\\TestPlotSelectedArea.pdf"
    lowerLeft(0) = 0: lowerLeft(1) = 0
    upperRight(0) = 297: upperRight(1) = 210
    With ThisDrawing.ActiveLayout
        .ConfigName = "DWG To PDF.pc3"
        .PlotType = acWindow
        .CenterPlot = True
        .PlotRotation = ac0degrees
    End With
    ' Read back window information
    ThisDrawing.ActiveLayout.GetWindowToPlot lowerLeft, upperRight
    MsgBox "Press any key to plot the following window:" & vbCrLf & vbCrLf & _
           "Lower Left: " & lowerLeft(0) & ", " & lowerLeft(1) & vbCrLf & _
           "Upper Right: " & upperRight(0) & ", " & upperRight(1)
    ThisDrawing.Plot.DisplayPlotPreview acFullPreview
    'ThisDrawing.Plot.PlotToFile plotFileName & ".pdf"
    'TestPlotSelectedAreaToPdf = True
    Exit Sub
ErrorHandler:
    'TestPlotSelectedAreaToPdf = False
End Sub
Ed
sonchai_n
I'm using the VBA code above with test2.dwg, but the plotted area in the output PDF does not match the expected coordinates.
Expected Plot Area (A4 - 297x210 mm)
at point X= 0.0000 Y= 0.0000 Z= 0.0000
at point X= 297.0000 Y= 0.0000 Z= 0.0000
at point X= 297.0000 Y= 210.0000 Z= 0.0000
at point X= 0.0000 Y= 210.0000 Z= 0.0000
Actual Plot Area in PDF
at point X=1933.1250 Y=-346.8750 Z= 0.0000
at point X=2230.1250 Y=-346.8750 Z= 0.0000
at point X=2230.1250 Y=-136.8750 Z= 0.0000
at point X=1933.1250 Y=-136.8750 Z= 0.0000
If anyone has encountered this issue or has suggestions, I would appreciate your help!
Thanks in advance.
Ed__Jobe
That's because the SetWindowToPlot function is not working. The "blank" area is what is already in the dwg. You need to find out if there is a setting in the dwg that is blocking the SetWindowToPlot function from working. Right now, only setting it within the PLOT command works. I told you how to compare drawing variables using the VARS2SCR command.
Ed
